02-07-2010, 05:18 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: anywhere
Member: 548078 Status: Offline Thanks Meter: 80 | 3120c wd Library version: 1.0.0.11985, Date: 03-02-2010 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0DD000102CE67C56218F9DD69D27B8FF5D785A5D ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0001 003F - 0000 8A21 [AMD ] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: B778DFBE4C5F277CE2DE8A38AF46E5D6803E4A79 Original Imei: 35685102905581 Original Product code: 0582800 Bluetooth ID: 00247CCA2E78 Phone Type: RM-364 (Nokia 3120 classic) SW Version: V 09.41 06-11-08 RM-364 (c) Nokia Imei plain: 35685102905581-7 Product Code: 0582800 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356851029055817 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF bro, do u have pm files of this unit. here is the logs below.. Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 09.41 06-11-08 RM-364 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F ERROR: Missing SD BLOCK or PM corrupted ! |
02-07-2010, 06:39 | #2 (permalink) |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | brother go imei and securty option then click imei rebuild option then click sdauth after sd update ok go in pm section and load pm and click super sd auth ur problem solve. always use sdauth to repair sd not super sd auth ok |
3120c RM-364 FIRMAWARE = 3120C RM-366??? | Pilarense | Universalbox | 1 | 01-27-2010 21:46 |
WD 3210 no keyboard | Beef | Nokia Hardware & Hardware Repair | 4 | 01-31-2007 09:08 |
Hw wd U change a gx15 imei????N e IDEA'S | Dutchking | Sharp | 14 | 10-17-2005 11:47 |
What about 2100? 1100? 2300? and WD-2?? | Burnt Cobba | Universalbox | 7 | 07-15-2005 17:12 |
THE NEW UFS[multi software f or nokia dct 3-4-l-wd---eric-moto 190-191-c330] | mobilemafia | UFS2 + UFS3-Tornadoflasher | 58 | 10-30-2003 18:03 |
