12-28-2009, 09:10 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: GREAT INDIA
Member: 559113 Status: Offline Sonork: 100.1596477 Thanks Meter: 760 | 6300 contact service Phone Type: RM-217 (Nokia 6300) SW Version: V 07.21 05-11-08 RM-217 (c) Nokia. Imei plain: 35983501293654-4 Product Code: 0546632 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 359835012936544 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
12-28-2009, 11:09 | #4 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | u beleve that info in mx key is right ?? CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 but its wrong in jaf & ub in jaf show CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000000000 then what we do ??? |
12-28-2009, 11:33 | #5 (permalink) |
Freak Poster Join Date: Jan 2005 Location: for sl3 phones Infinity best Age: 40
Member: 104393 Status: Offline Thanks Meter: 13 | first time do pm auth if writing like that ad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request you must do rpl service |
12-28-2009, 11:36 | #6 (permalink) |
Member: 104393 Status: Offline Thanks Meter: 13 | Connecting to server ...OK Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 94.20.58.150 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
12-28-2009, 12:05 | #7 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Quote:
FROM WHICH SET THIS INFO IS CAN U PLS EXPLAIN MORE. WBR sahil2000ind | |
12-28-2009, 12:53 | #8 (permalink) | |
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
like in mx ke show config data good but in ub & jaf its show conf data 0000000000000 & set in contact servise i do modified pm with sx4 but same condition | |
12-29-2009, 01:41 | #12 (permalink) |
No Life Poster Join Date: Nov 2005 Location: MoNiToR
Member: 199405 Status: Offline Sonork: 100.1576571 Thanks Meter: 322 | hello first u need 2 make downgrade from version 7.21 to lowest version(vr 7.21 have new firmware protection) now try making SX4 (u must have right access key,thats mean the superdongle must be valid or seem 2 be valid) after SX4 authoration done,write any pm have field 1 and 309 ***************************** another method: save full rpl backup,rest npc,write full pm,restore ur backup br |
12-29-2009, 06:34 | #14 (permalink) |
Member: 559113 Status: Offline Sonork: 100.1596477 Thanks Meter: 760 | Reset NPC write Full PM but problem same........ Imei: 35983501293654 Restoring RF/BB DATA from backup ... Updating RF ...OK Updating BB ...OK Updating WARRANTY ...OK Updating PROD ...OK Updating BT ...OK RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 10400103103A6E569ADFD13A4F75DEC351F3B127 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 NPC verified Ok. Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Updating PRODUCTCODE (0538334)... OK Updating PSN (DQA124026)... OK Updating HWID (1000)... OK Updating LOCK ...error 0x0 Updating WMDRM_PD...OK Certificate programmed successfully ! Phone Type: RM-217 (Nokia 6300) SW Version: V 07.21 05-11-08 RM-217 (c) Nokia. Imei plain: 35983501293654-4 Product Code: 0538334 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 359835012936544 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
12-29-2009, 07:30 | #15 (permalink) | |
nokia 5220 contact service 6300 contact service urgent please me | prakash40 | Nokia Hardware & Hardware Repair | 5 | 02-25-2010 09:56 |
6300 contact service after flash | tririval | MT-BOX | 3 | 08-16-2007 16:15 |
6300 contact service | ozeracar | MT-BOX | 1 | 07-31-2007 19:20 |
