05-02-2010, 10:46 | #5 (permalink) |
Freak Poster Join Date: Apr 2009 Location: New Delhi
Member: 1005011 Status: Offline Thanks Meter: 25 | her is my log Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8069(22-04-2010), 1.0.0.12843(27-04-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 1C200119A7187D56B90BD2DAB021378117643CBD ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 Original Imei: 35931702070711 Original Product code: 0573783 Bluetooth ID: 0024035F1AE4 Phone Type: RM-217 (Nokia 6300) SW Version: V 07.00 19-08-08 RM-217 (c) Nokia. Imei plain: 35931702070711-8 Product Code: 0573783 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35************** Version: SIMLOCK SERVER VERSION 63 Provider: KPN Telecom, Country: Netherlands Counter: 0/3, 0/10 CONFIG_DATA: 2040800000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 20408F, DATA=20408F BLOCK 2: 1=LOCKED (MCC+MNC): 20412F, DATA=20412F |
05-02-2010, 10:47 | #6 (permalink) | |
Freak Poster Join Date: Jan 2007 Location: Phillipines
Member: 437090 Status: Offline Thanks Meter: 131 | Quote:
phone is locked.... unlock your phone and your problem will be solved.. | |
05-02-2010, 11:02 | #9 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Nepal
Member: 622060 Status: Offline Thanks Meter: 37 | hi plz goto service imei ruibild option then update simlock then goto pm then chose load from file select the pm file then clock on the authpm option then write pm then now ur fone is fully unlocked |
06-12-2010, 11:56 | #15 (permalink) |
Freak Poster Join Date: Feb 2010 Location: india (telangana state) Age: 46
Member: 1230663 Status: Offline Sonork: 100.1593487 Thanks Meter: 174 | here the solution Phone Type: RM-217 (Nokia 6300) SW Version: V 07.21 05-11-08 RM-217 (c) Nokia. Imei plain: 35571402156278-7 Product Code: 0572715 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355714021562787 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED Imei net: 355714021562787 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED Backup saved to "BB5_35571402156278_SIMLOCK.back" Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 07.21 05-11-08 RM-217 (c) Nokia. SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F Sending SecondaryBoot [rap3gv3_2nd.fg](0x3D00 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x3948 bytes) ...OK Sending CustomLoader(0x50B0 bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x3B0 bytes) ...OK Calculating LOCK data ...OK Receiving Unlocked PM, please WAIT ... OK Unlocked PM saved to "C:\mobileEx\3.4\data\backup\355714021562787_UNLOC KED_308.1.PM" Writing Unlocked PM ... OK Completed in 27.172 s Restarting phone ... Reading Simlock info ... Imei net: 355714021562787 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 07.21 05-11-08 RM-217 (c) Nokia. Using cached productData[2DC0000B53CA7A56365E59F4BF376C9FCD7AF954] ... Calculating SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0 Completed in 2.625 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-217_355714021562787_SD.RPL" Updating SUPERDONGLE_KEY ...OK Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 07.21 05-11-08 RM-217 (c) Nokia. Using cached productData[2DC0000B53CA7A56365E59F4BF376C9FCD7AF954] ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0 Updating RFBB data ... Writing section 1... Writing section 309... done |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
