12-08-2010, 19:11 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | 6300 SUPERDONGLE_KEY invalid FFFFFFFFFFFFFFFF Phone Type: RM-217 (Nokia 6300) SW Version: V 07.30 07-05-09 RM-217 (c) Nokia. Imei plain: 35686402360978-6 Product Code: 0537632 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356864023609786 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED when i want to repair SD, i got this error ! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Product: V 07.30 07-05-09 RM-217 (c) Nokia. Boot error: 03 00 72 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. how to repair it ! |
12-08-2010, 19:22 | #4 (permalink) |
Member: 96141 Status: Offline Thanks Meter: 200 | can't repair simlock also Imei net: 356864023609786 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Product: V 07.30 07-05-09 RM-217 (c) Nokia. Boot error: 03 00 72 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Reading Simlock info ... i tryed with ufs, jaf and mtbox. but i think that simlock is ok, problem is in superdongle, as log said. |
12-08-2010, 19:34 | #5 (permalink) | |
Freak Poster Join Date: Sep 2006 Location: Zobi Mobile Lab Age: 35
Member: 352633 Status: Offline Sonork: Sun Set Of The Life Thanks Meter: 33 | Quote:
12-08-2010, 19:38 | #6 (permalink) |
Member: 96141 Status: Offline Thanks Meter: 200 | yes but i can't repair SD, see the log ! i got error, i also now try with bb5 boxinterface, with another type cable(wires in bat connector and connection from usb ) same problem, nothing happen ! |
C28 v61 when i use Swup say: invalid char received | xxxpaga | x1x to x45/x50 | 3 | 10-18-2001 18:36 |
StarTac 85-invalid batery! | gera5 | Motorola Old Legacy (EMMI) | 0 | 10-13-2001 17:38 |
StarTac 85-invalid batery! | gera5 | Motorola Old Legacy (EMMI) | 0 | 09-23-2001 23:37 |
Invalid sim on Nokia 6210 | dario | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-23-2001 02:19 |
help ! invalid battery | cyber6 | Motorola Old Legacy (EMMI) | 1 | 11-28-1999 06:11 |
