11-05-2012, 10:04 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: in iOs
Member: 563648 Status: Offline Sonork: 100.1594523 Thanks Meter: 87 | 6303c security test failed SW version: V 10.12 08-04-10 RM-443 (c) Nokia Imei plain: 35691403377683-4 Battery voltage: 4764 mV, current: 53 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 3---------------( imei ok) Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN repair SD SUPER SD auth write pm BUT NO LUCK need help |
11-05-2012, 10:09 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Go to Service Tab > Click Load from File > Select Address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-443.PM file, Now click Repair SD & click no to Pop Up Window, Click Write & Buscheck you will see the positive Result. BR, ZUBER |
11-05-2012, 10:57 | #3 (permalink) | |
Member: 563648 Status: Offline Sonork: 100.1594523 Thanks Meter: 87 | Quote:
i try with RM-443 pm (1 to 309 ) but no luck | |
12-09-2012, 19:50 | #8 (permalink) | |
My 6303c Ok Now Solved "Security Test Failed" By Write RPL Without NPC Data After Super SD And Write 1 to 309 PM Phone type: RM-443 (Nokia 6303 classic) SW version: V 10.12 08-04-10 RM-443 (c) Nokia Imei plain: 35691403377683-4 Product code: 0568857 Battery voltage: 4736 mV, current: 55 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356914033776834 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN thanks for support | |
12-10-2012, 19:43 | #9 (permalink) |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Good Work Dear We Happy Solved Your Problem..Enjoy With HTI.. BR. Arsalan gsm2000. |
The Following 3 Users Say Thank You to .::MASTER ALONE::. For This Useful Post: |
02-09-2013, 06:10 | #10 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: Bharat
Member: 1087883 Status: Offline Sonork: 100.1651719 Thanks Meter: 38 | Quote:
Thank you it's work for me | |
