Old 03-14-2010, 12:57   #1 (permalink)
khokonhajigonj's Avatar
Member: 771795
Sonork: 771795
Thanks Meter: 120
6500s problem
This set just open show nokia then blink and stop. I also try with rm-240_(mcu sw 3.80 & 4.81 & 4.84 & 6.60 & 7.12 & 8.30 & 9.40,9.60 and 10
but after last moment phone not restarting and not repair.
also try usb but last time it cant pooling and show phone not found
Old 03-14-2010, 13:24   #2 (permalink)
Member: 1223938
Sonork: naeemadil
Thanks Meter: 6
same prablom............
Old 03-14-2010, 13:30   #3 (permalink)
ufs3's Avatar
Member: 195332
Sonork: 100.1648961
Thanks Meter: 20
Its HW Problem Just Clean Your Board Tested By me Many times.
Old 03-14-2010, 13:33   #4 (permalink)
yobb's Avatar
Member: 337450
Thanks Meter: 718
Hardware problem, try to reheat some parts like, flash or cpu .
Old 03-14-2010, 13:51   #5 (permalink)
Member: 771795
Sonork: 771795
Thanks Meter: 120
also clean but same................................
Old 03-14-2010, 14:24   #6 (permalink)
Member: 554531
Thanks Meter: 85
post here your flashing log and bus check or scaning
Old 03-14-2010, 14:44   #7 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
go to mxkey >service>quick fix >bb5 sw downgrad fix
Old 03-14-2010, 14:45   #8 (permalink)
Master Software's Avatar
Member: 1149013
Thanks Meter: 247
Hardware problem...........................
Old 03-14-2010, 15:26   #9 (permalink)
ufs3's Avatar
Member: 195332
Sonork: 100.1648961
Thanks Meter: 20
Check This:
http://forum.gsmhosting.com/vbb/f148...n-here-887854/
Old 03-14-2010, 15:34   #10 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
u can remove this ic too ......... bro, do u have packup rpl?????????
Old 03-14-2010, 15:41   #11 (permalink)
Member: 771795
Sonork: 771795
Thanks Meter: 120
here is log
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.12027, Date: 06-02-2010
Processing file: rm240__09.40.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 20.36 MB
Supported RAP Ids: 0103192101003000, 010C192101003000, 030C192101023000
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1920010E82C95550D5D124BE41CE659ADB943FED
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0001 003F - 0000 8A21 [AMD ] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: A69838E8C5F20150E64E2E6E06DE6E50B26B593F
Total erase size: 21.87 MB
CMT NOR area [00000000-0001FFFF] erased in 0.859 s
CMT NOR area [00040000-000BFFFF] erased in 2.906 s
CMT NOR area [000C0000-0013FFFF] erased in 0.203 s
CMT NOR area [01480000-015FFFFF] erased in 8.250 s
CMT NOR area [00140000-0147FFFF] erased in 1 min 30.641 s
Flash programming ...
CMT PAPUBKEYS: A69838E8C5F20150E64E2E6E06DE6E50B26B593F (RAP Certificate 84 v1) written.
Programming completed in 2 min 29.360 s
Processing file: rm240__09.40.ppm_s as PPM
[BB5,BB5 ALGORITHM] size: 6.34 MB
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Total erase size: 6.75 MB
CMT NOR area [01600000-01CBFFFF] erased in 28.844 s
Programming completed in 51.547 s
Processing file: rm240__09.40_ism_017.image_w as CNT
[BB5,BB5 ALGORITHM] page size: 128 K size: 11.26 MB
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Total erase size: 34.87 MB
CMT NOR area [01FC0000-03F9FFFF] erased in 1 min 20.047 s
CMT NOR area [01CC0000-01FBFFFF] erased in 19.750 s
Programming completed in 1 min 25.406 s
Flashing completed in 9 min 49.547 s
Phone not responding !
Total time to process is 10 min 28.375 s
Old 03-14-2010, 15:56   #12 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
Old 03-14-2010, 17:31   #13 (permalink)
Member: 771795
Sonork: 771795
Thanks Meter: 120
its not posible bcoz phone not became in local or test mode
Old 03-14-2010, 17:39   #14 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
u can bro with ufx click read cert then go to mxkey and do my steps
full erase on mxkey
flash phone then chick if phone work or not
to repair imei go to ufx and click writ cert
Old 03-14-2010, 17:40   #15 (permalink)
Member: 771795
Sonork: 771795
Thanks Meter: 120
bro your solution for what set restart but its not restart it stop
6500s problem..ONLY "NOKIA" logo..hang on no boot.. thayalan HWK 39 08-10-2010 04:46
6500s problem flash via fbus raulka2003 Nokia Base Band 5 ( BB-5 ) 7 03-24-2009 07:32
6500s problem with flashing imanpanahi Nokia Base Band 5 ( BB-5 ) 0 01-24-2008 10:31
Page generated in 0.26838 seconds with 9 queries
