02-16-2010, 10:52 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | 6500s Rm-240 Restart problem have a look Code: Phone Type: RM-240 (Nokia 6500s-1) SW Version: V 06.60 07-03-08 RM-240 (c) Nokia Imei plain: 354837xxxxxxxx Product Code: 0549733 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed TimeStamp: 2008-03-14T09:26:00Z SW Version: 06.60 Variant Version: 013 ProductProfile: RM240_0549733_06.60_013.spr Simlock: 0549733_simlock.bin Imei net: 35483xxxxxxxxxx Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000002 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 06.60 07-03-08 RM-240 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Should i repair SD |
02-16-2010, 11:16 | #3 (permalink) | |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Quote:
but normal PMM AUTH is ok so should i repair SD and then auth SUPER SD ? Phone has restart problem | |
02-16-2010, 11:18 | #5 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Code: once superdongle is repaired u can't use normal PM auth if Super Dongle repaired with other box then i can't auth NORMAL PM AUTH but if super dongle repaired with MX-KEY i can auth Normal PMM |
02-16-2010, 11:22 | #6 (permalink) |
No Life Poster Join Date: Aug 2007 Location: india
Member: 573120 Status: Offline Thanks Meter: 145 | chk this post bro http:///vbb/...46#post5405446 |
02-16-2010, 11:25 | #7 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Code: Phone Type: RM-240 (Nokia 6500s-1) SW Version: V 06.60 07-03-08 RM-240 (c) Nokia Imei plain: 354837xxxxxxxxx Product Code: 0549733 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed |
02-16-2010, 11:28 | #8 (permalink) | |
i have valid certificates, valid simlock and valid security and valid Super dongle key and the other thing is i have PA SL2 phone | |
02-16-2010, 15:30 | #11 (permalink) |
No Life Poster Join Date: Apr 2005 Location: mars
Member: 132881 Status: Offline Thanks Meter: 105 | this your 1000000%%%%%%% solution if faced with that problem.i have nearly all nokia 6500s that have passed all tests in self-test run.try it.just remove teh mentioned components even without replacing them. http://forum.gsmhosting.com/vbb/show...00s+restarting |
6500s rm-240 restart !!?? | wizz25 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 03-23-2010 13:46 |
Nokia 6500S [RM 240] Flashing Problem | shinothalumkal | Universalbox | 5 | 10-24-2009 14:16 |
6500 rm-240 mmc problem | israrbjr | Nokia Base Band 5 ( BB-5 ) | 2 | 05-27-2009 14:29 |
6500s rm-240 restart !! | msantar | Nokia Base Band 5 ( BB-5 ) | 11 | 05-21-2009 13:26 |
6500s rm 240 restart problem after erase.... | memedyosep | Nokia Base Band 5 ( BB-5 ) | 2 | 02-15-2009 19:30 |
