Old 02-05-2010, 16:52   #1 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
>>>>what is this<<<<<
I have repair 2 sets in SD invalid Condtion with mx key and after repair sd sets all ok 1.6300 2.6233 but when i repair another 6300 sd after repair set on cs
when i busc heck both 6300 something diffrent
ok 6300 not show securty test pass
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11985, Date: 03-02-2010
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 26000216E1DF6F564B9F13A033F4ADD223C81CF1
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0001 0041 - 0000 6A21 [AMD ] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.17.0 revision: 0.0 size: 0x22E90
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9
Original Imei: 35204302498777
Original Product code: 0537631
Bluetooth ID: 001F00356308
Phone Type: RM-217 (Nokia 6300)
SW Version: V 05.50 14-08-07 RM-217 (c) Nokia.
Imei plain: 35204302498777-2
Product Code: 0537631
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Imei net: 352043024987772
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
cs 6300 show securty test failed
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 1C5001049A607A567A92F527A1DC95D16F875343
ASIC MODE ID: 00
Original Imei: 35351102577302
Original Product code: 0554543
Bluetooth ID: 002108181145
SW Version: V 07.30 07-05-09 RM-217 (c) Nokia.
Imei plain: 35351102577302-8
Product Code: 0537632
Language Pack:
- not available.
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 353511025773028
Counter: 0/3, 0/10
and 6233 same not show securty test option
y?
Old 02-05-2010, 17:01   #2 (permalink)
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
check this what is this
Old 02-05-2010, 18:45   #3 (permalink)
Member: 255072
Thanks Meter: 46
pm auth then write pm blocks just 1 and 309
Old 02-05-2010, 18:51   #4 (permalink)
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
after repair sd with mx key ppm auth not work
Old 02-05-2010, 19:04   #5 (permalink)
ROEZT's Avatar
Member: 508048
Thanks Meter: 123
same:d.....................
Need unlock code for VDF136 new firmware here is dump. azeem781986 FuriousGold 16 05-26-2010 04:48
where is 2700 c-2 ngaia MXKEY Nokia Flasher and Unlocker (by Alim Hape) 11 04-12-2010 08:15
my black berry 8100 is not unlock (Answered) ravin j tejura MXKEY Blackberry Flasher and Unlocker (by Alim Hape) 11 04-08-2010 15:05
What is the problem? fun MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-29-2010 15:48
SE w395 i want to unlock.....what is this problem? adamsquall Universalbox 2 03-29-2010 14:11
Page generated in 0.18526 seconds with 9 queries
