03-21-2010, 05:50 | #1 (permalink) |
Major Poster Join Date: Sep 2009
Member: 1116765 Status: Offline Thanks Meter: 17 | 7120c SUPERDONGLE_KEY invalid,SIMLOCK invalid!done. thanks mxkey team! procedure 1. backup RPL(just in case). 2. make sim lock rpl 3. Repair SD 4. SUPER SD Auth 5. Write PM1,309 Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35574302729086-1 Language Pack: - not available. SIMLOCK invalid!! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Product: V 07.23 17-07-09 RM-436 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Calculating SIMLOCK using security server ... Completed in 13.782 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-436_355743027290861_SIM.RPL" Updating SIMLOCK...OK Reading Simlock info ... Imei net: 355743027290861 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 238001098AD158504E466701C88428CAD211E40B ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 Original Imei: 35574302729086 Original Product code: 0566924 Bluetooth ID: 0023B40F111A Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35574302729086-1 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355743027290861 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Product: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData[238001098AD158504E466701C88428CAD211E40B] ... Calculating SUPERDONGLE using security server ... Completed in 24.781 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-436_355743027290861_SIMSD.RPL" Updating SUPERDONGLE_KEY ...OK Updating SIMLOCK...OK Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Product: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData[238001098AD158504E466701C88428CAD211E40B] ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! Writing PM from Node ... Section: 1 - Key: 0, size 12 bytes written. - Key: 2, size 70 bytes written. - Key: 3, size 70 bytes written. - Key: 4, size 70 bytes written. - Key: 6, size 276 bytes written. - Key: 7, size 276 bytes written. - Key: 8, size 276 bytes written. - Key: 10, size 384 bytes written. - Key: 11, size 384 bytes written. - Key: 12, size 384 bytes written. - Key: 14, size 384 bytes written. - Key: 15, size 384 bytes written. - Key: 16, size 384 bytes written. - Key: 17, size 32 bytes written. - Key: 19, size 16 bytes written. - 120 skipped Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. - Key: 22, size 12 bytes written. Completed in 2.688 s finish Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35574302729086-1 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355743027290861 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
The Following User Says Thank You to ...sewren... For This Useful Post: |
** 7210c SimLock Invalid & SuperDongleKey Invalid Done ** | kungpaoski | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 33 | 04-07-2011 07:49 |
nokia 5130 SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SE | >>.123.<< | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 10-24-2010 11:05 |
SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK TEST failed! SECURITY_T | >>.123.<< | Nokia Base Band 5 ( BB-5 ) | 6 | 04-19-2010 10:26 |
nokia 5130 SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SE | >>.123.<< | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 02-17-2010 05:29 |
Help 7310c simlock superdongle_key invalid and invalid | nardisk | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 01-29-2010 19:38 |
