Old 05-30-2011, 12:36   #1 (permalink)
dualsimcect's Avatar
Member: 72330
Sonork: 100.1604259
Thanks Meter: 35
E51 blue screen (ANSWERED)
I have E51 blue screen and restart after 20 seconds, solution? Thanks
Old 05-30-2011, 12:51   #2 (permalink)
..:: Devil_king ::..'s Avatar
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
post scan info and self test
Old 05-30-2011, 13:10   #3 (permalink)
Member: 222970
Thanks Meter: 8
Try to flash your phone with E51_blank_504KB_pmm_10 from this post as MCU
http://forum.gsmhosting.com/vbb/f148...1/#post4952784
Then reflash as usual with latest firmware.
Old 05-30-2011, 13:18   #4 (permalink)
Member: 72330
Sonork: 100.1604259
Thanks Meter: 35
Phone not responding, but I can flash with same result... trying with E51_blank_504KB_pmm_10 now
Old 05-30-2011, 13:24   #5 (permalink)
Member: 72330
Sonork: 100.1604259
Thanks Meter: 35
thnaks,working now
Old 11-15-2011, 20:27   #6 (permalink)
Member: 1689897
Smile
Originally Posted by paulfc View Post
thnaks,working now
Thank you deab2001; machaon2005 & paulfc
paulfc,
I have the same problem blue screen with my nokia E51.
Please advice how did you used E51_blank_504KB_pmm_10
How can i put it in MCU? and what does it mean MCU.
thank you for help
Old 11-15-2011, 20:34   #7 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
paulfc,
thank you for help
i believe you landed here by google.
do you have HTI device?
DO this, no need any files:
example on different rap based phones. ignore any difference logs / version.
- if problem still remain, flash the phone once more.
- if problem still remain after flash, i have no idea. check phone HW.
- post buscheck logs of your phone.
Old 11-15-2011, 20:49   #8 (permalink)
Member: 1689897
Thanks gbluez,
you are right i land here by google.
I'm sorry to say I dont know about HTI, but I searched in your forum and found the folloing post
http://forum.gsmhosting.com/vbb/f550...1-how-1267078/
I'm not sure if you mean that? if yes then I will go through it (as it is the first time for me in it).
For the buscheck logs, I'm sorry to ask you again how to find it.
Thanks for your time and Patient.
Maytham
Old 11-15-2011, 21:03   #9 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Hi,
HTI is a professional nokia service suite.
You will need HTI Box,
and E51 FBUS cable.
I saw your IP is from UAE, you can buy all this tool in here:
DISTRIBUTOR:
WORLDWIDE:
TECHNIQUE STYLE TRADING
CONTACT PERSON: ANSARTEC-DUBAI(UAE)
SHOP NO-2, LOOTAH BUILDING
BEHIND MASHREQUE BANK
OPP. HYAT REGENCY, MUSSALLA ROAD
DEIRA DUBAI, UAE
Tel: +971-4-2731768
FAX: +97142247868
ICQ: 272143839
sonork user id: 100.101633
sonork name: ANSARI
MSN: [email protected]
E-mail: [email protected]
Website: Welcome to TST-GSM.com
Old 11-15-2011, 21:14   #10 (permalink)
Member: 1689897
Thank you gbluez,
yes you are right i'm from UAE.
After I buy HTI box, then what I should do please.
It seems to be big job!!!!
Please what is the MCU?
Old 11-15-2011, 21:24   #11 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
So, you will buy all those device, just for your E51? great.
You will need to visit MXKEY to know more about it.
You will need to be active in this is forum to be a software engineer.
Yes, it's a big job
MCU: micro control unit, part of phone firmware.
The Following User Says Thank You to gbluez For This Useful Post:
Old 12-08-2011, 15:35   #12 (permalink)
Member: 1689897
Thank you gbluez,
The problem with my mobile was the connector between the device to the screen of the device.
After I dismantled the E51 device disconnect the connector clean and fix bac, the E51 device working properly now.
The connector was lose and dirty.
So before go to any firmware update please check the hardware is connected properly, clean, everything in place and working properly.
Thanks once again for prompt response and help.
Old 06-28-2012, 15:21   #13 (permalink)
salehgsm's Avatar
Member: 884539
Sonork: salehgsm
Thanks Meter: 28
write pmm blank as mcu by hwk e51 blue screen removed 100%
BLUE light Delfo Nokia Hardware & Hardware Repair 8 09-20-2002 04:28
Screening indicator cxara Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-09-1999 09:13
blue Display in Nokia Cellphones TheDon Nokia Hardware & Hardware Repair 0 10-29-1999 18:28
blue led? Michael Go Wanted Products 0 09-10-1999 00:57
Page generated in 0.20081 seconds with 9 queries
