7210 supernova_SECURITY_TEST failed! (ANSWERED) 7210 supernova_SECURITY_TEST failed! Quote:
http://forum.gsmhosting.com/vbb/f550...wered-1311542/ and http://forum.gsmhosting.com/vbb/f550...x-key-1269895/ All i tried but failed. What To Do Next? |
- recover certificate - repair sd. it should be VERY easy BR |
SAME RESULT SECURITY_TEST failed! |
please start self test. BR |
Another story... http://my.jetscreenshot.com/7540/m_2...sjni-143kb.jpg http://my.jetscreenshot.com/7540/m_2...22it-168kb.jpg @ gbluez if u can pls connect me in teamviewer to check Check your pm |
Please follow this steps: 1.1st u backup imei data/ncp data. 2.read pm file and then save pm data. 3.erase pm data 4.load new full pm data 5.repair sd 6.super sd auth/pm auth 7.then write pm with 1-309 field 8.update simlock i hope you will be happy plz try this ..... i have done many sets to follow this system via mx-key. (mx-key is the best tool forever brother!!....) bro, raj systel. |
write pm 1 + 309 if not write good "ccc + hwc" Quote:
go to quick fix ---->Select BB5 sw downgrade fix ---> and do job :) all will be ok 300% Br |
this method erase ncp + ccc + hwc and writed again :) |
Another one..:( i done all what you told me as solution......But i cant do only SECURITY_TEST failed! with my this box.But other box can solve this...... http://my.jetscreenshot.com/7540/m_2...kb9g-147kb.jpg http://my.jetscreenshot.com/7540/m_2...ld5m-178kb.jpg Thanks to all ... |
Sometimes it is a bug in the program Turn on the phone probably works !!!! |
[QUOTE=Dr.Dekra;8165156]Sometimes it is a bug in the program Turn on the phone probably works !!!![/QUOTE] Check This..Borother... Only two in this video and log posted above.... |
please post the writing pm log if possible, just to make sure u did it correctly. br |
@.:EXTREME:. try 3.5-1.6 vers sometime better for repair Security than 3.5-1.7 (some people think this superstition):) |
if you are free you can use my desktop.. just buzz me in sonork or yahoo.. 100.1606509 [email protected] fone connected and waiting for you...;) |
