08-09-2009, 15:36 | #1 (permalink) |
Banned Join Date: Nov 2007 Age: 36
Member: 631286 Status: Offline Thanks Meter: 1,250 | MXKEY update: v3.2 revision 3.2, Public-Release v3.2 revision 3.2, Public-Release Whats new: - Application core module loader routine changed - MAIN Minor bug fix - NK JAF BOX stability and compatibility improved (This will also fix problem with flash dead,random stops/hang when using JAF BOX) Added, Bus Check routine for 'Nokia USB ROM' (Useful for 'NORMAL' phones which could not connect to USB due to phone lock or something else) (After successful flash bus check phone will reboot to local mode, so you can do fbus operation such as: reset user code/factory reset) Added, Wlan settings in RF/BB tab Fixed, Keypad test start bug Fixed, Sometimes hang after flash erase Wlan settings also included when backing up ProgData MXKEY support forum: https://forum.gsmhosting.com/vbb/f550/ MXKEY updates thread: http://forum.gsmhosting.com/vbb/showthread.php?t=685905 PS: Just discovered Krombo identity and will be made public soon. |
08-09-2009, 19:16 | #2 (permalink) |
No Life Poster Join Date: Mar 2005 Location: indiamobilesolution Age: 72
Member: 121938 Status: Offline Sonork: 1001590655 Thanks Meter: 1,028 | MXKEY update: v3.2 revision 3.2, Public-Release this releases on 06-08-2009 i had posted here on 08-08-09 but some one delete my post MX-Key mobileEx v3.2 revision 3.2,Public-Release New v3.2 revision 3.2, Public-Release 06.08.2009 #Minor update - MAIN Minor bugfix - NK JAF BOX stability and compability improved ~ This will also fix problem with flash dead,random stops/hang when using JAF BOX Added, Bus Check routine for 'Nokia USB ROM' ~ Usefull for 'NORMAL' phones which could not connect to USB due to phone lock or something else ~ After sucessfull flash bus check phone will reboot to local mode, so you can do fbus operation such as: reset user code/factory reset Added, Wlan settings in RF/BB tab Fixed, Keypad test start bug Fixed, Sometimes hang after flash erase Wlan settings also included when backing up ProgData |
v3.2 revision 3.0, Public-Release not work in bb5 model | prakashmborana | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 20 | 07-16-2009 04:42 |
MXKEY v3.2 revision 3.0, Public-Release | MANOLE | Service Products News & Updates | 0 | 07-01-2009 20:22 |
