7210c contact service how to solv 7210c contanct service.with mxkey pls help me |
post here info log ................................... if security test fail then write pm with sx4 |
Free File Hosting & Video Downloads, Free File Sharing, Online Friends Network - Ziddu HERE THE SOLUTION FOR NOKIA 7210C CONTACT SERVICE If after repair SD and/or Simlock (Super Dongle RPL and Simlock RPL upload) you get "SECURITY_TEST failed!" and/or "warning: SD authorized but verify failed!". This is comming usually because some PM fields and/or RPL sections are missing from your phone (e.g. DRM keys, CCC, ...). Solution 1 (easy way, maybe not work all time, depends how phone was damaged): - write full PM from SAME phone model (product number) WITHOUT fields 1, 308, 309 (and WITHOUT field 120 for SL20 based phones) - unplug/replug phone from JAF/UFS box - make Simlock RPL repair - make SD RPL repair - unplug/replug phone from JAF/UFS box - make SUPER SX4 Auth then write PM1 and PM309 if still have problems, use Solution 2: - backup RPL (NPC, CCC, HWC, ...), will call this ORIGINAL RPL - backup RPL from another working phone (same model) with SAME product code - edit this good RPL from another phone and remove NPC section (all lines who start with NPC_DATA_1 ... NPC_DATA_xx), will call this edited file CLONE RPL - backup full PM from another working phone (same model) with SAME product code, will call this file CLONE PM - full erase flash chip (use erase file regarding flash chip size) - flash phone (CMT, APE, ...) - upload CLONE RPL - upload ORIGINAL RPL - write full CLONE PM without fields 1,120,308,309 - unplug/replug phone from JAF/UFS box - make Simlock RPL repair - make SD RPL repair - unplug/replug phone from JAF/UFS box - make SUPER SX4 Auth then write PM1 and PM309 IF IT'S OK SAY THANKS BR PRAJITHKUMAR:)) |
post your ful log..... if your phone get "SECURITY_TEST failed!" then write sx4 modified pm....which....write pm 1 & 309..... your problem 100% solved..... or other if your phone when power on instant show contact service....without see "start up phone with out sin card" it a hardware shorting problem.... br, Aniaxn |
repair sd repair simlock good |
