Old 09-03-2009, 08:45   #1 (permalink)
Member: 240856
Thanks Meter: 82
7210c contact service
7210c handset hang old ver 4.36 flesh new ver 5.60 after flash contact service plz solution
Old 09-03-2009, 08:49   #2 (permalink)
gsmTECHNICIAN's Avatar
Member: 922938
Thanks Meter: 59
for my experience all my encounter like this problem 80 % RPL because of SP DATA CORRUPTED
10% use sx4 any box support sx4
5% program 5% hardware
regards
..::GsmMobile::..
Old 09-03-2009, 10:54   #3 (permalink)
Member: 240856
Thanks Meter: 82
regards
..::GsmMobile::..
SP DATA not Corrupted
use sx4 same
any soulation
Old 09-03-2009, 20:32   #4 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
Thanks Meter: 322
simlock on st is ok
only security have error
@ mobilecareke
SX4 without right pm will not help
try this
The Following User Says Thank You to mohA™ For This Useful Post:
Old 09-04-2009, 07:39   #5 (permalink)
Member: 240856
Thanks Meter: 82
Originally Posted by mohA™ View Post
simlock on st is ok
@ mobilecareke
try this
Same condesion............................
Old 09-04-2009, 07:44   #6 (permalink)
Nokia-Shop's Avatar
Member: 1008571
Sonork: 100.1590905
Thanks Meter: 95
mate bye rpl for that set
Nokia Shop
The Following User Says Thank You to Nokia-Shop For This Useful Post:
Old 12-05-2009, 16:02   #7 (permalink)
Registered User
Member: 806063
Sonork: becozbecoz
Thanks Meter: 26
i have a hanging problem. hanging & restarting complaint. if any solution. pls reply me.
Old 12-05-2009, 16:08   #8 (permalink)
d.jain's Avatar
Member: 670629
Sonork: 100.1590208
Thanks Meter: 431
write pm file with sx4 auth youerset is 1000000% ok
Old 12-05-2009, 16:44   #9 (permalink)
Member: 548078
Thanks Meter: 80
bro, used modified pm and write SX4uth, your problem is solved, because it is security test failed. using mx-key.
read this below.
http://forum.gsmhosting.com/vbb/showthread.php?t=874487
Old 12-05-2009, 17:06   #10 (permalink)
Member: 1091079
Thanks Meter: 13
any one solution 5310 contact service
Old 12-05-2009, 19:07   #11 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
Are you able to get the SX4 auth? if yes and still security test failed, write back the RPL back-up and retry again to do the sx4 auth and the good PM.
If you can't obtain the sx4 auth your mobile has superdongle problem and this explane the restarting (watch dog)
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 12-06-2009, 07:08   #12 (permalink)
Member: 1160909
Thanks Meter: 6
Alex
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
i'm sure superdong is ok...i check it use ohert tool.
i want to write pm to the phone..but i can't connect the x4...
any idea?
Old 12-07-2009, 01:56   #13 (permalink)
moulnisky's Avatar
Member: 947561
Lot of people has problems with the 7210.
I can tell you that if you rebuilt the Superdongle using the "other tool" I think you are not the only one having this problem..
About checking the superdongle if is valid or not, I can tell you for experience the only valid test is the SX4 auth
Alex
Old 03-07-2010, 16:50   #14 (permalink)
Member: 786337
pl's give me a7210c flesh file for j.a.f
Old 03-07-2010, 16:52   #15 (permalink)
Member: 786337
pl's give me 7210c flesh file.............................................. ............................................!
Nokia 7210c contact service NIMESHFONOTLY Nokia Hardware & Hardware Repair 78 08-23-2012 13:31
7210c contact service plz hlp fofolpo Nokia Base Band 5 ( BB-5 ) 2 04-02-2009 09:41
Page generated in 0.21435 seconds with 10 queries
