Old 08-01-2010, 09:10   #1 (permalink)
Member: 583468
Sonork: 100.1592004
Thanks Meter: 106
online IMEI working
Online IMEI LOger Work again here is log
ASIC ID: 0x2201 [UPP_2M ver: 2]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0101 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.80.0 revision: 0.7 size: 0x5718
Performing Flash Authentication ...OK
UEM ID: 005803A4:2984DA60
ASIC type: 2
UEM Imei: 35807301865292
SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1
RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35807301865292.RP L"
FlashID1: 0000 0001 [unused/removed]
Programming FLASH Imei ...failed
Programming UEM Imei (OTP) ...
UEM programmed successfully.
Phone Type: RH-64
SW Version: V 7.02 10-12-07 RH-64 (c) NMP
Imei plain: 35807301865292-0
Product Code: 0525392
Cellular System: GSM
ASIC ID: 0x2201, type: 2
Ppm Id: MG
Language Pack:
English,Hindi,Marathi
Imei net: 35807301865292
Version:
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000000002
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
but Programming FLASH Imei ...failed
Is that Ok
Old 08-01-2010, 12:38   #2 (permalink)
Member: 1086393
Thanks Meter: 771
yes. oki man enjoy
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 04-06-2012 16:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 11-21-2011 01:44
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 08:41
Page generated in 0.17798 seconds with 9 queries
