Old 03-18-2010, 10:10   #1 (permalink)
.:Ripgsm:.'s Avatar
Member: 125945
Thanks Meter: 495
Question Please help "no security dongle detected"
Please, I really have so many phones to be repaired, I was an unknown error.
"NO SECURITY DONGLE DETECTED", please help me, I read, if I remember correctly, that the paper goes into protection and crashes.
I tried everything, is one night when I uninstall / reinstall everything, but nothing.
The dongle is seen correctly by the PC, SP3, Win XP, rokey200 drivers are installed, but nothing.
He started first with an error reading or writing memory, then it was stuck on a procedure that was doing it on a N73 with the hourglass, but since there was so much, and had given me the ERROR 0x1, as I tried to repair the sim-lock, I closed everything to try to fix that bug, (I have the leadership and I have repaired it many times) but when I go to restart the sw Mx-Key, with Jaf connected with cables f/bus as always and I never had any problem before he started to give me the NOKIA screen for a few seconds, until, and dead.
Still the damn error "NO DONGLE SECRURITY DETECTED".
At this point, I try on another pc, I installed everything from the beginning, and Stan, I see that everything worked perfectly, even though on that PC, I installed the SW of Jaf 1.98.64 emulator, but not have launched.
The Jaf is vers. 2.0, the SW that I use is vers. 1.98.62.
All according to me, began when I closed MX without waiting ended, there is a solution to this error? Now bringing back the PC 1 day I created 2 folders MOBILEEX.exe 3.6, with the renamed files in second folder, where I have the whole library, but in fact opens with the colors that I had set myself.
Please have a nice little phones to do, can you help me?, Not can I use another PC, because I have everything here I need for procedures, do first to fix this error to bring up all in another PC, which among other things, in another laboratory.
Thank you
Max
The Following User Says Thank You to .:Ripgsm:. For This Useful Post:
Old 03-18-2010, 11:32   #2 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
unplug any scard reader.
uninstall all any scard driver and token driver from device manager
run uninst.exe in folder
C:\mobileEx\3.3\data\drivers\card\FT2K
restart PC.
then install instDrv_stdRK200.exe in same directory.
plugin your MXKEY dongle.
if looking new driver , seem like working good
try open MXKEY software .
hope fully help
br,
Old 03-18-2010, 11:58   #3 (permalink)
.:Ripgsm:.'s Avatar
Member: 125945
Thanks Meter: 495
restart PC.
hope fully help
br,
Ok, but now i disinstall all?
Now, because i have installated the UFS+Kwk K***R, when have disinstallated all whith Revo Uninstaller.
But probabily that i have cancellated files of librery, and have to do other point of ripristin, exactament, first of disinstall this UFS....., and now, how have writed, i have 2 folder whith 2 mobileEx.exe 3.3 (rev.1.6), in hone have small folder in the secon have my library and if i open mobileEx, have ugual set how i haved first.
Now is this the situation, loock this pictures, please
Old 03-18-2010, 12:04   #4 (permalink)
.:Ripgsm:.'s Avatar
Member: 125945
Thanks Meter: 495
Please Ser, i not have other scard reader in this moment plug in.
Or i have need of disinstall alls my scard reader for scar motorola, p.key reader ecc..., for e.g.?
the SW MX that i have 2, uninstall betwen?
Old 03-18-2010, 12:11   #5 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
read this carefully
all thinks about driver.
not MXKEY software
br,
The Following User Says Thank You to Andra For This Useful Post:
Old 03-18-2010, 12:49   #6 (permalink)
.:Ripgsm:.'s Avatar
Member: 125945
Thanks Meter: 495
read this carefully
not MXKEY software
br,
Yes, ser, i have disinstallated ALLS the smarcard Driver from Device manager, now i now have nothing of the driver, how to see in photo, but now i have 2, TWO sw "mobileEx", how the photo of the other post.
I want know where disinstall?, becouse one not have more item that have the "mobilEx" only, this "mobilEx2" was rename from window when i have go back the pc of 1 day, do u understand now?
and one ultime question, the Rokey200 and Axsalto driver i have also in Installation/application, have need of remove these also?
Now this is the situation:
Old 03-18-2010, 13:39   #7 (permalink)
.:Ripgsm:.'s Avatar
Member: 125945
Thanks Meter: 495
restart PC.
hope fully help
br,
SOLVEDDDDDD!!!!
THANK YOU
and i'm from tonight for one S***T of the driver, have tested all, nothing, how forever, not want that give THANK to MK KEY, in the moment, for repair SD, are only this, and FOR FREE, what is 40$ for one card?, one coffe for day in one mounth........
Now, i want to put other one my periferic?, scard, and others?
or return the problem?, go urgent to test and repair this SD demaged, thank you
Max
Old 03-18-2010, 13:44   #8 (permalink)
.:Ripgsm:.'s Avatar
Member: 125945
Thanks Meter: 495
Yes i know that other one answere writing that have more cyclone that repair this SD, but i have buyed and for LUCKY, have sendede urgentement, have need one advance study for understand this box, and not is reality that is for FREE, for the operation pay...., whith Mx, not pay nothing, i have too, the 2010 credit and shure that have repaired more phones....
Max
Old 03-18-2010, 15:10   #9 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
congratulation , max.
glad to know that. have a nice day with mxkey.
Old 03-18-2010, 15:22   #10 (permalink)
eletrico's Avatar
Member: 729325
Sonork: 1581738
Thanks Meter: 890
Exclamation
how to fix this erro ????
help!!!
help!!!
how to fix this erro ??????
Old 03-18-2010, 15:25   #11 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
is this error comes when you try to connecting a ufs device?
all needed driver are placed inside C:\mobileEx\3.3\data\drivers.
please, reinstall from there.
Old 03-18-2010, 15:28   #12 (permalink)
.:Ripgsm:.'s Avatar
Member: 125945
Thanks Meter: 495
Click Yes and install the Nokia connectivity cable driver, or go in C:\mobileEx\3.3\data\drivers\nokia, click install and have solved..
Old 03-18-2010, 15:37   #13 (permalink)
.:Ripgsm:.'s Avatar
Member: 125945
Thanks Meter: 495
have buyed from 2 mounths, and when have solved, (this card small, that i not thinked), 2 E71 whith SD for repair, i have buyed immeditly, and have repaire these 2 E71 in one moment, from this time i use more and mor Mx key, now have one N73 that is alls ok, self test ok in all, but when i verific whith Jaf, receive Conf.Key 0000000 and provvider 24407, but the phone is unlocked, not have one battery charged, (have one lot of N95 and N958gb), for test this have need battery that is in charged....., ok, for one Driver, not are using my Mx-key....i not understand too..., important is solved
br
Max
HELP!!! No Security Dongle Detected Problem abellcell MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 12-22-2009 12:12
[HELP] "Not Security Dongle Detected" fusarista MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 05-29-2009 06:53
help no security dongle alfin5557 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 03-25-2009 17:58
Please help, 8910 Security Code....... doughnut23 Nokia Digital Core Technology 4 ( DCT-4 ) 8 03-09-2004 19:22
Please help, 8910 Security Code....... doughnut23 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-18-2004 09:55
Page generated in 0.25234 seconds with 10 queries
