05-17-2010, 08:39 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Bangladesh Age: 40
Member: 717313 Status: Offline Sonork: 100.1611706 Thanks Meter: 45 | 7210c(RM-436) This is log.......... Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 04.87 08-08-08 RM-436 (c) Nokia Imei plain: 35574302488931-9 Product Code: 0566903 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 355743024889319 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF RepairSD Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 04.87 08-08-08 RM-436 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Calculating SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0 Completed in 14.250 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-436_355743024889319_SD.RPL" Updating SUPERDONGLE_KEY ...OK Super SD Auth Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 04.87 08-08-08 RM-436 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Restarting phone ... Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request plz help............................ |
05-17-2010, 09:19 | #4 (permalink) |
Freak Poster Join Date: Dec 2006 Location: Khartoum-Sudan
Member: 420318 Status: Offline Sonork: 100.1661057 Thanks Meter: 65 | hey bro try to write pm 1 , 309 many time then do recover certificated it works for me plz tell us the result good luck |
The Following User Says Thank You to sudsud For This Useful Post: |
05-17-2010, 10:18 | #6 (permalink) |
Member: 717313 Status: Offline Sonork: 100.1611706 Thanks Meter: 45 | Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (12 bytes) Warning: failed to write 1 - 2 (70 bytes) Warning: failed to write 1 - 3 (70 bytes) Warning: failed to write 1 - 4 (70 bytes) Warning: failed to write 1 - 6 (276 bytes) Warning: failed to write 1 - 7 (276 bytes) Warning: failed to write 1 - 8 (276 bytes) Warning: failed to write 1 - 10 (384 bytes) Warning: failed to write 1 - 11 (384 bytes) Warning: failed to write 1 - 12 (384 bytes) Warning: failed to write 1 - 14 (384 bytes) Warning: failed to write 1 - 15 (384 bytes) Warning: failed to write 1 - 16 (384 bytes) Warning: failed to write 1 - 17 (32 bytes) Warning: failed to write 1 - 19 (16 bytes) Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Completed in 5.391 s |
05-17-2010, 10:20 | #7 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: :::::::EMIRATES:::::::
Member: 591669 Status: Offline Sonork: 110011 Thanks Meter: 687 | Quote:
you only write pm....! first press Super SD Auth............and write pm 1 & 309 | |
05-17-2010, 15:10 | #8 (permalink) |
Member: 717313 Status: Offline Sonork: 100.1611706 Thanks Meter: 45 | Super SD Auth not done............ Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 04.87 08-08-08 RM-436 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Restarting phone ... Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request plz help............................ |
05-17-2010, 15:50 | #9 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: benguerdene-TUNISIA
Member: 558412 Status: Offline Thanks Meter: 117 | Quote:
- write full pm doesn t matter modified or not - make sl rpl -sd rpl repair -auth sx4+write good 1abd 309 pm | |
05-17-2010, 15:58 | #10 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Indonesia
Member: 1169189 Status: Offline Sonork: 100.1591528 Thanks Meter: 94 | Failed writing PM because he can't reach the server. Please select another server in server list.... If you sure have valid backup, both RPL and PM. Write PM with resetting NPC. Carefully, |
The Following User Says Thank You to sijibae For This Useful Post: |
05-18-2010, 08:44 | #15 (permalink) |
Product Supporter Join Date: Oct 2009 Location: Mumbai. Great India
Member: 1135304 Status: Offline Sonork: 100.1592050 QQ:3549168141 Thanks Meter: 4,071 | try this bro: http://forum.gsmhosting.com/vbb/f299...1000-a-965626/ |
