02-13-2010, 03:06 | #1 (permalink) |
Freak Poster Join Date: Nov 2007 Location: India/Malaysia
Member: 641058 Status: Offline Sonork: 100.1589325 Thanks Meter: 140 | 7210c sd and simlock invalid success fully solved Original Imei: 35574xxxxxxxxxxx Original Product code: 0566902 Bluetooth ID: 0022FCB9D036 Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35574xxxxxxxx-9 Product Code: 0514950 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! -WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! i try repair sd in mx-key after that got SECURITY_TEST failed sphameed finally got fixed this problem with this way 1, repair sd using mx-key(after that security_test failed repair simlock not done with mx-key always show access violation error) 2, repair simlock using UB (20credit ) after that procedure simlock valid and sd valid only security test failed 3, upload pm field 1,309 using mx-key super auth button (no error) result SIMLOCK valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed set working fine sphameed |
1112 version 6.40 and 6.41 success fully unlock by HWK | GUDO-GSM | HWK | 22 | 06-27-2012 18:38 |
7210c simlock invalid help how solve | rajeshbahri | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 02-04-2010 10:39 |
How To Repair 7210C,5220 Etc....Simlock Invalid | SHIJILFONOTLY | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 01-29-2010 11:41 |
Another 7210c Repaired [CS with SD and simlock corrupt] | alfox | Universalbox | 1 | 01-16-2010 11:08 |
7210c Rm-436 simlock invalid & contact service repaired ok_whith UB | sinhcuibap | Universalbox | 1 | 12-19-2009 12:10 |
