Old 01-25-2010, 11:18   #1 (permalink)
Member: 565282
Thanks Meter: 22
7210c simlock data corrupted need help![OLD POST]
Version Info:
MCU SW version: V 07.23 17-07-09 RM-436 (c) Nokia
HW version: 1000
RFIC version: 064c0601
DSP version: ICPR72_09w17
LCD version: SHARP
PPM version: V 07.23 17-07-09 RM-436 (c) Nokia C
BT MCM version: 2222-143C
Retu version: 15
Tahvo version: 22
Product Info:
Production serial number: DTC703940
Product code: 0566924
Module code: 0203868
Basic production code: 0563951
Long production SN: 0
Serial Numbers:
IMEI plain: 359310020174454
IMEI spare to net: 3A 95 13 00 02 71 44 05
IMEI SV to net: 33 95 13 00 02 71 44 45 F0
Other Info:
Model : Nokia 7210 Supernova (Live)
CS type : GSM900/GSM1800/GSM1900
BSI: 5.8 KOhm
SIMLOCK_DATA corrupted!
mx-key masters i need help!
regards
Old 01-25-2010, 11:30   #2 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,073
Seem problem plz help me
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 35574302639150-4
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
Old 01-25-2010, 12:24   #3 (permalink)
xnk
Member: 206938
same problem here, need update......
The Following User Says Thank You to xnk For This Useful Post:
Old 01-25-2010, 12:26   #4 (permalink)
Umair Rashid's Avatar
Member: 421117
Sonork: +92 346 5544377 (PHONE)
Thanks Meter: 2,522
Post your logs and pm first.
Old 01-25-2010, 13:13   #5 (permalink)
xnk
Member: 206938
The condition is same as the 1st post,
when i try to recover cert, 'it says no certificate found in database'
Old 01-25-2010, 13:30   #6 (permalink)
Member: 789335
Thanks Meter: 3
Language Pack:
- not available.
SIMLOCK invalid!
look like your superdongle corrupt bro...
for simlock may be mx-key can repair it...
but for superdongel mx-key cannot repair it for now!
u can use another tool and need credit...
i hope mx-key can solve this problem on next up date
Old 01-25-2010, 13:39   #7 (permalink)
Member: 862011
Thanks Meter: 55
Use ub tool nd ub cradit to repair superdongle
Old 01-25-2010, 13:58   #8 (permalink)
xannix_7575's Avatar
Member: 847117
Thanks Meter: 71
just wait for MXKEY or CYLONE for thier UPDATE...
DONT ever try to REPAIR with UB you just WASTE you CREDITS
Old 01-25-2010, 14:43   #9 (permalink)
UNLOCK PARK ®'s Avatar
Member: 1004001
Sonork: WhatsApp+971506319003
Thanks Meter: 448
write rpl
br,
gsm_yousuf
Old 01-25-2010, 16:25   #10 (permalink)
Crazy Poster
Member: 1210570
Thanks Meter: 3
Cool
ur fone will b aluive again
u need to repaur sl zone in mxkey
but ur watchdog timew will b enabled
for this u need ub to calculate sd
Old 01-25-2010, 17:26   #11 (permalink)
Member: 583492
Thanks Meter: 125
connect jaf or hwk.. wth jaf nokia bb5 no tp unlocker just repair sl zone ur pc will b fine
The Following User Says Thank You to afhaan For This Useful Post:
Old 01-26-2010, 09:23   #12 (permalink)
Member: 421117
Thanks Meter: 2,522
Originally Posted by supersonic-x View Post
mx-key where is the solution?
still waiting for the answer!
regards
In the start you post only "phone info"
Unless you post complete logs we cant help you.
Old 01-27-2010, 17:46   #13 (permalink)
sushilsoni2003's Avatar
Member: 99115
Thanks Meter: 99
Version Info:
HW version: 1000
LCD version: SHARP
Retu version: 15
Tahvo version: 22
Product Info:
Serial Numbers:
Other Info:
BSI: 5.8 KOhm
regards
In universal box make loke repair+ generate superdongle= 50 credits = Rs. 650
Your Set will be ok.
Old 02-01-2010, 15:29   #14 (permalink)
Crazy Poster
Member: 1210570
Thanks Meter: 3
ub will solve ur problem
do as sushil said
sp + sd in ub will work
Old 02-01-2010, 15:49   #15 (permalink)
Member: 811173
Thanks Meter: 9
1 ) repaie simlock
2) u need mt box p gensx4 not free 12 credit
tested 1000$
good luck
7210 Simlock Data Corrupt Need Help satzone MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 02-03-2010 20:35
5220 simlock-data corrupted need help reymon Nokia Base Band 5 ( BB-5 ) 4 02-01-2010 08:11
2600c simlock data corrupted help forever MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 11-15-2009 12:27
Please help repair E71, simlock data corrupted jdwe Nokia Base Band 5 ( BB-5 ) 5 07-31-2009 08:21
Page generated in 0.25289 seconds with 9 queries
