Old 02-11-2010, 03:56   #1 (permalink)
kungpaoski's Avatar
Member: 329609
Thanks Meter: 245
** 7210c SimLock Invalid & SuperDongleKey Invalid Done **
Phone Problem:SimLock Invalid & SuperDongleKey Invalid phone in Contact Service
Procedure:
1.Repair SimLock first
-Tick Imei & Security tab
-Tick Simlock
-Put check repair simlock
-Put check make simlock rpl
-Tick repair splock tab
2.Repair Superdonglekey
-Tick Imei Rebuild tab
-Tick Repair SD
-After Successful SD repair make Bus Check
-SuperDongle Key is now valid
-Need to repair Security Test failed
3.Repair Security Test failed
-Tick PM tab
-Tick Super SD Auth tab
-Once SuperDongle is authorized
-Load 7210c PM File ( PM 1 and PM 309 )
-Tick load file tab and select your PM file
-Tick write Tab
Make Bus check afterwards to see if all went fine
Phone fully repaired
b.r.
The Following 46 Users Say Thank You to kungpaoski For This Useful Post:
Old 02-11-2010, 04:07   #2 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
nice boss reference to us some of user we need this explanation good job..........go go go mx team
The Following 2 Users Say Thank You to lilong_lee For This Useful Post:
Old 02-11-2010, 04:10   #3 (permalink)
Member: 305311
Thanks Meter: 227
pls upload all pm you got there mate
The Following User Says Thank You to ronkiton For This Useful Post:
Old 02-11-2010, 04:12   #4 (permalink)
Ligalig's Avatar
Member: 1079935
Thanks Meter: 511
congratsssssssssssss mate. long live pinoy
eto po:
TESTED with :::
3110c
7210c
E71
E63
heres the LINKS::
http://rapidshare.com/files/34797849..._ONLY.rar.html
http://www.megaupload.com/?d=Y3CGX5ZW
http://www.uploadmb.com/dw.php?id=1265683285
The Following 6 Users Say Thank You to Ligalig For This Useful Post:
Old 02-11-2010, 04:15   #5 (permalink)
Temporary banned !!
Member: 1151970
Sonork: 100.1597000
Thanks Meter: 378
good job tested buy me good mxkey team....................
The Following User Says Thank You to KIKO_GSM For This Useful Post:
Old 02-11-2010, 04:21   #6 (permalink)
kungpaoski's Avatar
Member: 329609
Thanks Meter: 245
heres the PM File I used : RM-436_PM1 and PM 309 only.rar
b.r.
The Following User Says Thank You to kungpaoski For This Useful Post:
Old 04-08-2010, 08:25   #7 (permalink)
Member: 706692
Sonork: english
Thanks Meter: 7
Thumbs up thank 1000% ok thank 1000% ok thank 1000% ok thank 1000% ok
Procedure:
-Tick Simlock
-Tick Repair SD
-Tick PM tab
-Tick write Tab
b.r.
Old 04-08-2010, 08:59   #8 (permalink)
Member: 816217
Thanks Meter: 25
this information very useful for new user... .Thanks
Old 05-29-2010, 10:11   #9 (permalink)
Member: 750874
Thanks Meter: 20
thanksssssssssssssssssssssssssssss
Old 05-29-2010, 10:21   #10 (permalink)
pepe67's Avatar
Member: 568492
Thanks Meter: 230
Good job Bro, many thanks info!
Old 05-29-2010, 10:32   #11 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
Procedure:
-Tick Simlock
-Tick Repair SD
-Tick PM tab
-Tick write Tab
b.r.
Every thing is ok but super sd au not working why????
Old 05-29-2010, 10:34   #12 (permalink)
Member: 1096393
Nice one sir, this should be sticky cause it would really help us alot guys.... keep on sharing master kungpaoski.... Long Live PILIPINO!
Old 08-15-2010, 10:20   #13 (permalink)
avi4uni's Avatar
Member: 713765
Thanks Meter: 41
Thank u & thank u very much sir it's work 1000%
Old 08-19-2010, 07:50   #14 (permalink)
meeza_84's Avatar
Member: 279362
Sonork: 100.1594141
Thanks Meter: 500
nice sharing bro keep it up
Old 08-21-2010, 07:28   #15 (permalink)
faruk_gsm's Avatar
Member: 877161
Thanks Meter: 48
The Following 2 Users Say Thank You to faruk_gsm For This Useful Post:
7210c simlock invalid lorenzo roberto MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 01-23-2010 12:40
7210c simlock info invalid shahid41 Universalbox 2 01-17-2010 15:21
7210c Rm-436 simlock invalid & contact service repaired ok_whith UB sinhcuibap Universalbox 1 12-19-2009 12:10
7210c simlock info invalid ivanrommel Universalbox 5 11-29-2009 11:52
7210c simlock info invalid sr8787 Universalbox 1 11-14-2009 17:16
Page generated in 0.19954 seconds with 10 queries
