7210c SIMLOCK_DATA corrupted! i have one 7210c simlock data corrupted how ican repair this Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 05.61 10-12-08 RM-436 (c) Nokia Imei plain: 35523103956096-8 Language Pack: - not available. SIMLOCK_DATA corrupted! |
REgards |
first try with repair sim lock ,if not susses then if you have backup then restore imei after that pm auth then write 1, 309 pm filed . |
7210c simlock SIMLOCK_DATA corrupted! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Product: V 05.61 10-12-08 RM-436 (c) Nokia Using cached productData[1590000AC2CF8A56FD190210566165FE63234ED8] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host3, agent version 1.1 revision 0.5 Completed in 2.203 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-436_355231039560968_SIM.RPL" Updating SIMLOCK...OK Reading Simlock info ... SIMLOCK_DATA corrupted |
just unlock and rapeir simlock with mark rpl |
SIMLOCK_DATA corrupted! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Product: V 05.61 10-12-08 RM-436 (c) Nokia Using cached productData[1590000AC2CF8A56FD190210566165FE63234ED8] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host3, agent version 1.1 revision 0.5 Completed in 8.734 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-436_355231039560968_SIM.RPL" Updating SIMLOCK...error 0x14 Reading Simlock info ... SIMLOCK_DATA corrupted! |
ok , make backup ur phone imei (npc data) first , erase flash , reflash phone with latest version , restore imei , resote other certificates (hwc,ccc data) from server . repair superdongle key of ur phone , make super pm auth & write pm 1-309 . then make repair simlock using simlock rpl from server. I think ur phone should repair now , if not please let me know or u may contact me on yahoo or sonork. |
check make rpl buckup below > click rapir SL, ;) |
- Flash > advanced > erase > get address : untick 'safe erase', select eeprom , do erase. - repair simlock by make simlock rpl - repair sd, proceed to any pm auth directly. do not load any pm, mark load RFBB from server. write after auth successful. - check camera function, write dcc if needed. |
base on my experience as shown logs.. I think your phone show nokia only and goes white screen.. repair simlock doesn't help due to program corupt.. Just full flash your phone then you will see if it is simlock test failed or simlock invalid.. post result |
yes my phone show nokia only and goes white screen this is log Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 04.87 08-08-08 RM-436 (c) Nokia Imei plain: 35523103956096-8 Language Pack: - not available. SIMLOCK_DATA corrupted! plese help |
SIMLOCK_DATA corrupted! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Product: V 04.87 08-08-08 RM-436 (c) Nokia Using cached productData[1590000AC2CF8A56FD190210566165FE63234ED8] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host3, agent version 1.1 revision 0.5 Completed in 6.453 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-436_355231039560968_SIM.RPL" Updating SIMLOCK...OK Reading Simlock info ... SIMLOCK_DATA corrupted! |
