7210s not enough memory (ANSWERED) 7210s (RM-436) problem not enough memory,not connecting/booting with USB cable, I've already flash with v7.23 via FBUS cable but problem not solve then I take backup and full erase,again flash restore backup but problem same not enough memory . Is there any way to solve problem with fbus cable? if yes tell me how can I sole this? |
Did you try factory reset? |
Yes already tried factory reset,user data etc. |
try using cnt file lower than 11mb................... |
bro just flash at cnt file u r problem will solve 1000% |
try this way bro: http://forum.gsmhosting.com/vbb/f148...lution-972515/ |
Flash only cnt file, Your problem will solve... |
DON'T tick 'safe erase' BR |
I FLASH WITH LETEST VER. WITH USB 100% OK MEMROY NOT ENOUGH SEE IN LOG Library version: 1.0.0.9274(01-03-2011), 1.0.0.15868(10-03-2011) Processing MCU file: rm436__07.23.mcusw [BB5,BB5 ALGORITHM] size: 18.06 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2313F17C CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] CMT EM0 ID: 00000295 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 11B0001261297D56952FF5F3ED91686BA5859257 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x4AD00 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x59700 bytes Update Server code succesfully sent to phone. Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 20AEA35 Verifying communication to device OK. Erase size: 19.12 MB CMT NOR area [00000000-000006BF] erased in 0.610 s CMT NOR area [000006C0-0001FFFF] erased in 0.578 s CMT NOR area [00040000-000BFFFF] erased in 2.969 s CMT NOR area [000C0000-0013FFFF] erased in 2.531 s CMT NOR area [00140000-0119FFFF] erased in 1 min 21.984 s CMT NOR area [011A0000-0133FFFF] erased in 8.406 s Flash programming ... CMT PAPUBKEYS: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 (RAP Certificate 142 v.1) written. Programming completed in 1 min 21.265 s Processing PPM file: rm436__07.23.ppm_mb [BB5,BB5 ALGORITHM] size: 6.15 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 8.62 MB CMT NOR area [01340000-01BDFFFF] erased in 40.953 s Flash programming ... Programming completed in 28.250 s Processing CNT file: rm436__07.23.image_mb [BB5,BB5 ALGORITHM] page size: 128 K size: 20.27 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 35.87 MB CMT NOR area [01BE0000-01F7FFFF] erased in 25.015 s CMT NOR area [01F80000-03FBFFFF] erased in 3 min 51.781 s Flash programming ... Programming completed in 1 min 49.547 s Total time for flashing process(boot+erase+write) was 10 min 50.750 s Waiting for device boot up ... Device found: nmwcdc\Nokia 7210 Supernova USB Phonet, PORT_ID: 421CCEE Verifying communication to device OK. Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35*************** Product Code: 0572571 Battery voltage: 3960 mV Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35**************** Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK Completed in 1.219 s |
