10-18-2012, 18:56 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Morocco
Member: 382783 Status: Offline Thanks Meter: 124 | Nokia 7210c contact service !!!!!! i flashed nokia 7210c gaves problem just shows Nokia & white screen i erased the phone & i reflashed it again but when i powered the phone & i pressed accept gaves contact service this is log SLPA ver[1]: PA_SL (15 digit NCK) Camera config: NIMMIIIIRRFF094B2F01, ver: XXX.XXX warning: DCC corrupted ! SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
10-18-2012, 19:42 | #2 (permalink) |
Member: 382783 Status: Offline Thanks Meter: 124 | OK i repaired some errors but remais one this is log SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK) Camera config: NIMMIIIIRRFF094B2F01, ver: XXX.XXX warning: DCC corrupted ! SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 355743023407626 Version: SIMLOCK SERVER Counter: 0/3, 0/10 |
10-18-2012, 19:49 | #3 (permalink) | |
Freak Poster Join Date: Sep 2008
Member: 853097 Status: Offline Sonork: 100.1622287 Thanks Meter: 131 | Quote:
10-18-2012, 20:03 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Go to Service Tab > Click Load from File > Select Address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-436.PM file, Now click Repair SD & click no to Pop Up Window, Click Write & Buscheck you will see the positive Result. Later Check Camera & it's Connector contacts or Change Camera. BR, ZUBER |
10-18-2012, 20:24 | #5 (permalink) | |
Member: 382783 Status: Offline Thanks Meter: 124 | Quote:
i clicked repair SD it's OK Done when i clicked write gaves problem: writing:failed to write (for all sections) | |
10-18-2012, 20:38 | #6 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Clean PCB for Waterlogs, Reflow Avilma & Combo ICs for Physical Damage, Must solve it, BR, ZUBER | |
10-18-2012, 21:28 | #9 (permalink) |
Member: 382783 Status: Offline Thanks Meter: 124 | Thanks for your helps Bros But the problem still SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK) Camera config: NIMMIIIIRRFF094B2F01, ver: XXX.XXX warning: DCC corrupted ! SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 355743023407626 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 |
