05-30-2011, 17:46 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Bangladesh Age: 41
Member: 648647 Status: Offline Sonork: 100.1603328 Thanks Meter: 967 | 7230s rm604 flashing error pls help.......... (ANSWERED) Bus check logg ............................. MXKEY Serial: [FT SCR2 Driver: NMWCD, ver: 7.1.32.62, NTMP ver: Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: EE7A64E CMT SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 1A300214B3C55540B2479807A123730F537E2449 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D CMT ROM ID: 67E82268F29CEA60 Loading CMT secondary boot code SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3B40 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0098 0030 - 0000 0131 [Toshiba NAND-1G] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Loading CMT update server data Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 10.22.0 revision: 3.0 size: 0x8F9A0 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: EE7A64E Verifying communication to device OK. Original Imei: 35536504415546 Original Product code: 0590626 Bluetooth ID: 942053A9BEAF SIMLOCK PA identifier: [0] PA_SL3 Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Waiting for device boot up ... Phone not found, retrying ... After flash log .................................................. ....... MXKEY Serial: [FT SCR200 Driver: NMWCD, ver: 7.1.32.62, NTMP ver: Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) Processing MCU file: rm598__06.90.mcusw [BB5,XSR 1.6] size: 28.75 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: EE7A64E CMT SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 1A300214B3C55540B2479807A123730F537E2449 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D CMT ROM ID: 67E82268F29CEA60 Loading CMT secondary boot code SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3B40 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0098 0030 - 0000 0131 [Toshiba NAND-1G] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Loading CMT update server data Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 10.22.0 revision: 3.0 size: 0x8F9A0 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: EE7A64E Verifying communication to device OK. CMT PAPUBKEYS HASH: 4431C834027BBA0D18A5ED745CAFA04BA679A74A Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 37.69 MB CMT MuxOneNAND area [00020000-000203FF] CMT MuxOneNAND area [00060000-0009FFFF] CMT MuxOneNAND area [000A0000-0025FFFF] CMT MuxOneNAND area [003E0000-005DFFFF] CMT MuxOneNAND area [005E0000-010DFFFF] CMT MuxOneNAND area [01EC0000-01EDFFFF] CMT MuxOneNAND area [027C0000-02CBFFFF] CMT MuxOneNAND area [077C0000-07B3FFFF] CMT MuxOneNAND area [010E0000-01EBFFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 4431C834027BBA0D18A5ED745CAFA04BA679A74A (RAP Certificate 192 v.1) sent CMT RAP3NAND block sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 54.468 s Processing PPM file: rm598__06.90.ppm_a [BB5,XSR 1.6] size: 6.40 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Erase size: 8.87 MB CMT MuxOneNAND area [01EE0000-027BFFFF] Flash programming ... Programming completed in 11.610 s Processing CNT file: rm598__06.90.image_a_0589901_003 [BB5,XSR 1.6] size: 12.48 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Erase size: 75.06 MB CMT MuxOneNAND area [02CC0000-077BFFFF] Formating partition ... Flash programming ... Programming completed in 23.516 s Total time for flashing process(boot+erase+write) was 1 min 44.719 s Waiting for device boot up ... Phone not found, retrying ... pls tell me what is worng?????????????????? |
05-31-2011, 04:52 | #2 (permalink) | |
Member: 648647 Status: Offline Sonork: 100.1603328 Thanks Meter: 967 | Quote:
