04-04-2010, 12:17 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: pondicherry Age: 38
Member: 687128 Status: Offline Thanks Meter: 261 | 7250i problem Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) ASIC ID: 0x1120 [UPP_8M ver: 2.0 or 2.1 or 2.2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00D47467:2984DA60 ASIC type: 2 UEM Imei: 37295500931296 Flash Imei: 35295500931296 MasterCode: 0051414607 Invalid imei checksum ! Phone Type: NHL-4JX (Nokia 7250i) SW Version: V 5.41 09-02-05 NHL-4JX (c) Nokia. Imei plain: ??????????????-? Imei OTP: 37295500931296 Product Code: 0510760 Cellular System: GSM ASIC ID: 0x1120, type: 2 Ppm Id: A Language Pack: English,Finnish,Swedish,Danish,Norwegian,German,Ic elandic Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: SIMLOCKLIB VERSION 2.28 -fix task:Extended number of TDS-6 boxes Counter: 0/3, 0/10 CONFIG_DATA: E588A8C976047478 PROFILE_BITS: 10DDF22CDF25D1DD SIMLOCK_DATA corrupted! |
04-04-2010, 13:03 | #2 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Mizoram>>Aizawl
Member: 1014781 Status: Offline Thanks Meter: 177 | Quote:
Youre IMEI is not valid, if it support, then you have to use online logger for RPL.You can serch the forum to check if it support or not and the procedure. | |
jar jad game files 7250i problem | fender62 | Nokia Multimedia | 3 | 01-09-2005 07:42 |
7250i problem | TITO | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 05-30-2004 07:31 |
7250i problem | prasse | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 05-04-2004 05:58 |
nokia 7250i problem | blueyesdude | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 02-22-2004 15:30 |
