04-06-2010, 04:22 | #1 (permalink) |
Registered User Join Date: Jun 2005 Location: isla pilipinas Age: 19
Member: 153549 Status: Offline Thanks Meter: 13 | 7310c contact service...PLS HELP here's the logs Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 06B00013606E57508E80F601A990BE0A796A49D4 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 1C4FF759B84A261249E1BBE6F8B6CED06F54373D Original Imei: 35355002987334 Original Product code: 0559925 Bluetooth ID: 0021087D3C5E Phone Type: RM-379 (Nokia 7310 Supernova) SW Version: V 09.40 06-11-08 RM-379 (c) Nokia Imei plain: 35355002987334-3 Product Code: 0559925 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353550029873343 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF selftest Phone Type: RM-379 SW version: V 09.40 06-11-08 RM-379 (c) Nokia ID Test name Startup Result 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 15 SLEEP_X_LOOP Y passed 46 UEM_CBUS_IF Y passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N passed 43 LCD N passed 21 LPRF_IF N !not ready 44 LPRF_AUDIO_LINES N !not ready 2 CURRENT_CONS N !not ready 42 RADIO Y !not ready 69 BACKLIGHT Y passed 33 SIM_LOCK N passed 93 SECURITY N passed 71 BT_WAKEUP N !not ready 96 HOOKINT N !not ready 88 TAHVOINT Y !not ready 56 SLEEPCLK_FREQ N !not ready 101 BTEMP N !not ready 107 BT_SLEEP_CLK N !not ready 115 TVOUT_IF N !not ready 119 IIC N passed 108 EXT_DEVICE N passed 86 CDSP_RF_BB_IF N passed 83 CDSP_RF_SUPPLY N passed 80 CDSP_TX_PLL_PHASE_LOCK N passed 81 CDSP_RX_IQ_LOOP_BACK N passed 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) how to solve this CS?. |
04-06-2010, 04:31 | #2 (permalink) |
No Life Poster Join Date: Jul 2008 Location: BHARAT Age: 42
Member: 823633 Status: Offline Thanks Meter: 1,705 | bro check here http://forum.gsmhosting.com/vbb/f528...8/#post5672889 |
04-06-2010, 04:43 | #3 (permalink) | |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | Quote:
SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed all test passed so why write pm rebool avilma or change if still then cpu can be faulty | |
04-06-2010, 05:04 | #4 (permalink) |
Freak Poster Join Date: Jan 2009 Location: Bruteforce cheap
Member: 943039 Status: Offline Sonork: 100.1604242 Thanks Meter: 41 | Just try recover cert in tab imei rebuild ,still not ok , back up ur imei , and try replace hwc,nwc data from support ,still not, back up full and erase ,start from the begining B.R |
04-06-2010, 05:17 | #6 (permalink) |
Member: 153549 Status: Offline Thanks Meter: 13 | problem solved.... i rehot the parts and write pm 1 and 309 and now it is ok.....tnx |
The Following User Says Thank You to crossroads For This Useful Post: |
7310c contact service...PLS HELP | crossroads | Cyclonebox | 9 | 04-06-2010 04:54 |
1100 contact service. pls help | chaudry | Nokia Hardware & Hardware Repair | 5 | 02-21-2010 06:25 |
nokia6270 contact service pls help | sajidmirza | Nokia Hardware & Hardware Repair | 6 | 05-28-2007 04:09 |
6220 Contact Service Pls Help me!!! | zoltranfull | Griffin | 1 | 07-11-2005 13:13 |
3310-4.19 version ...... contact service.....pls help!!!! | PTR999 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 12 | 01-18-2002 18:18 |
