09-20-2012, 17:36 | #1 (permalink) |
Major Poster Join Date: Mar 2008 Location: any where
Member: 720915 Status: Offline Sonork: 4824472 Thanks Meter: 9 | 8520 no service network |
09-20-2012, 19:15 | #2 (permalink) |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | Sorry, I do not understand your error. Post screen shots to be more clear. BR, Manole |
The Following User Says Thank You to MANOLE For This Useful Post: |
09-21-2012, 06:50 | #3 (permalink) | |
Member: 720915 Status: Offline Sonork: 4824472 Thanks Meter: 9 | Quote:
when i type MEPD on the sim card in the blackberry menu then look like this sim dissable network dissable network subset disable service provider dissable all dissable so it means device already unlock.. but when i check via mxkey log says IMEI: 357750032569559 MEP: MEP-04104-007 Factory Lock State: CLOSED MXKEY Serial: MEP2 (Network, Active, 19.10): 6414214444597206 MEP3 (Network Subset): 8971978408399112 MEP4 (Service Provider): 7817189426628147 MEP5 (Corporate): 8815231451750406 I've tried to write MEP2, but nothing appear to write screen when type MEP2 (Unlock procedure) please help present condition no network service,how can do open the lock factory state | |
09-21-2012, 09:15 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Make Hard Reset, Scan Phone & Calculate MEP, Try enter Codes, if not works post Logs. BR, ZUBER |
The Following 2 Users Say Thank You to .::ZUBER::. For This Useful Post: |
09-21-2012, 11:17 | #5 (permalink) |
Member: 720915 Status: Offline Sonork: 4824472 Thanks Meter: 9 | i tried hard reset then instal os but still same condition IMEI: 357750032569559 MEP: MEP-04104-007 Factory Lock State: CLOSED MXKEY Serial: MEP2(Network,Active,19,10): 6414214444597206 MEP3(Network Subset): 8971978408399112 MEP4(Service Provider): 7817189426628147 MEP5(Corporate): 8815231451750406 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and "2" NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code(6414214444597206) and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and "2"<<<<<<no respon does not appear to write MEP code |
09-21-2012, 13:01 | #7 (permalink) |
Insane Poster Join Date: Mar 2008 Location: factoryunlocked
Member: 717516 Status: Offline Sonork: 100.1620938 Thanks Meter: 5 | Remove the SIM card Go to "Settings" -> "Options" Select "Advanced options" or "Advanced system settings" -> "SIM Card" Type "mep" then [ALT BUTTON] and "2" appear to write MEP code (6414214444597206) done.. |
The Following User Says Thank You to teleteknik1985 For This Useful Post: |
09-22-2012, 17:14 | #9 (permalink) |
Freak Poster Join Date: Apr 2006 Location: MX-KEY is the BEST NOKIA TOOL
Member: 258446 Status: Offline Thanks Meter: 26 | phone already unlock, put sim and search network, network setting 3g or gsm or maybe phone have signal (network) issue or maybe the radio still off, turn it on.. Last edited by antee7; 09-22-2012 at 17:19. |
