05-12-2010, 19:08 | #3 (permalink) |
Freak Poster Join Date: May 2004 Location: morocco Age: 52
Member: 65817 Status: Offline Thanks Meter: 12 | yes its down i can't unlock dct4plus Imei net: 35199304032801 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 6040000000000000 PROFILE_BITS: 8000000000010002 BLOCK 1: 1.LOCKED (MCC+MNC): 60400F Calculating SIMLOCK RPL using security server ... program blocked in this step! Last edited by lahoucine; 05-12-2010 at 19:14. |
05-12-2010, 19:37 | #4 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Dominican Republic
Member: 469532 Status: Offline Sonork: TG: CodebUnlocks Thanks Meter: 868 | Quote:
Server is working fine..... Imei net: 01168400970813 Version: SIMLOCK SERVER Provider: CINGULAR - Pacific Bell Wireless, Country: U.S.A. Counter: 0/3, 0/10 CONFIG_DATA: 3101700000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 310150 BLOCK 2: 1.LOCKED (MCC+MNC): 310170 BLOCK 3: 1.LOCKED (MCC+MNC): 311180 BLOCK 4: 1.LOCKED (MCC+MNC): 310410 BLOCK 5: 1.LOCKED (MCC+MNC): 310980 Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-87_01168400970813_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 01168400970813 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN | |
The Following User Says Thank You to Mr_F10ch3 For This Useful Post: |
05-12-2010, 19:46 | #5 (permalink) |
Junior Member Join Date: May 2010 Location: Jamaica
Member: 1301337 Status: Offline Thanks Meter: 1 | intermitent the issue seems to be intermittent right now the application is not even recognizing my dongle Seeing : No Security Dongle Detected Was working fine before I have to be restarting the app constantly to see if it'll work |
05-12-2010, 20:29 | #6 (permalink) |
Member: 65817 Status: Offline Thanks Meter: 12 | Server is working fine now: Imei net: 35154504877784 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 6040000000000000 PROFILE_BITS: 8000000000010002 BLOCK 1: 1.LOCKED (MCC+MNC): 60400F Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-105_35154504877784_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35154504877784 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
05-13-2010, 08:01 | #7 (permalink) |
Banned Join Date: Sep 2009 Location: PM P L Z Age: 36
Member: 1116719 Status: Offline Thanks Meter: 542 | canning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello ip..... Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
new server! | komix | GSM Mobile Links | 0 | 05-12-2001 07:56 |
I moved my web site on the faster server, please test it. Thank you. | westerna | GSM Mobile Links | 1 | 04-26-2001 10:33 |
FREE SOFTWARE + FTP SERVER | tronix | GSM Mobile Links | 1 | 04-23-2001 21:43 |
1,4 GB GSM Software on FTP-Server... | tronix | GSM Mobile Links | 1 | 04-03-2001 17:08 |
1,4 GB GSM SOFTWARE ON FTP-SERVER | tronix | GSM Mobile Links | 0 | 03-19-2001 17:58 |
