04-29-2010, 00:47 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Tunisia
Member: 411207 Status: Offline Thanks Meter: 164 | about all certs????? can MX-KEY restore all certs(NPC+HWC+KEYCMT...) read with other tools. i try and i can't.also with downgrade but some problem. now my phone with imei damaged like 12345********* |
04-29-2010, 10:59 | #4 (permalink) |
Member: 411207 Status: Offline Thanks Meter: 164 | here my check bus Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8069(22-04-2010), 1.0.0.12843(27-04-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0CB00116B81B03543435796386F656C7689101A1 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 Original Imei: Empty Original Product code: Empty NPC_DATA invalid ! Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 12345610654321-? Product Code: 0566808 Language Pack: - not available. Imei plain is invalid !!! SIMLOCK_DATA corrupted! |
04-29-2010, 11:44 | #5 (permalink) |
Member: 411207 Status: Offline Thanks Meter: 164 | ok i try and try and my phone have the original imei. very thks MX-KEY Code: Restoring RF/BB DATA from backup ... Updating RF ...OK Updating BB ...OK Updating PROD ...OK Updating BT ...OK RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0CB00116B81B03543435796386F656C7689101A1 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Updating PRODUCTCODE (0566808)... OK Updating PSN (DTC023281)... OK Updating HWID (1000)... OK Updating SIMLOCK...error 0x14 Trying to update SUPERDONGLE_KEY ...error 0x0 Updating WMDRM_PD...OK Certificate programmed successfully ! Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35574302069099-2 Product Code: 0566808 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! SIMLOCK_DATA corrupted! |
04-29-2010, 12:17 | #6 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, i see u're using HWK. Now write PM by using this file, RM-436_355743020690992_28042010_093757.rar If those backup doesn't work, you will need to repair it's simlock. but you also got SECURITY_TEST failed! so, please check it first by using http://forum.gsmhosting.com/vbb/f550...-mxkey-906760/ BR |
04-29-2010, 12:51 | #7 (permalink) |
Member: 411207 Status: Offline Thanks Meter: 164 | i try with this PM and my problem not solved. after write pm modified with field1+309 i reaired trhe test security but my problem now with simlock invalid i try all solution available here and nothing. my problem like this membre here i confirmed i try all solution but my problem not solved the log of scan Code: Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35574302069099-2 Product Code: 0566808 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST passed SIMLOCK_DATA corrupted! |
04-29-2010, 14:51 | #8 (permalink) |
Member: 411207 Status: Offline Thanks Meter: 164 | when i try to recovry cert Code: RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0CB00116B81B03543435796386F656C7689101A1 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 Reading RAP NPC (0x168 bytes) Begin Certificate Request ... Connecting to server ...OK, Login ... ERROR: No certificate found in the database ! Code: Product: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData[0CB00116B81B03543435796386F656C7689101A1] ... Calculating SUPERDONGLE using security server ... Completed in 2.391 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-436_355743020690992_SIMSD.RPL" Updating SUPERDONGLE_KEY ...OK Updating SIMLOCK...error 0x14 Code: Product: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData[0CB00116B81B03543435796386F656C7689101A1] ... Calculating SIMLOCK using security server ... Completed in 1.031 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-436_355743020690992_SIM.RPL" Updating SIMLOCK...error 0x14 Reading Simlock info ... SIMLOCK_DATA corrupted! i try to erase all certs with/without downgrade SO, any other idea. |
04-29-2010, 15:10 | #9 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | Quote:
backup rpl rest npc go to pm click erase pm writ rpl then click recover cert repair sd (you will get rpl to repair sim & sd) go to pm >click SUPER SD AUTH and writ pm fullfactory&format | |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
I am looking for information about GSM-CABLES.NE | DUPOND | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 08-03-1999 15:29 |
all for GSM: http://fly.to/spear | spear | GSM Mobile Links | 0 | 07-11-1999 22:01 |
Question about 51xx/61xx | Comic | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-06-1999 23:47 |
