Old 02-16-2012, 10:03   #1 (permalink)
Member: 1700720
Thanks Meter: 19
Question actually what to do for SECURITY_TEST failed!? (ANSWERED)
1. load PM or mark load RFBB from server > Press Repair SD > follow on screen message
or
2. load PM or mark load RFBB from server > Press Super SD auth > Press Write
or
3. load PM or mark load RFBB from server > Repair SD > Super SD auth > Press Write
& what about load pm full pm or 1, 309 only
& what about mark load RFBB from server
The Following User Says Thank You to softpick For This Useful Post:
Old 02-16-2012, 10:51   #2 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
use SEARCH button and try them all by yourself, learning by doing...
br
Old 02-16-2012, 11:07   #3 (permalink)
Member: 1673829
Thanks Meter: 22
good question. many people facing SECURITY_TEST failed problem unsolved. i think it's depend on situation. product supporter MANOLE or gbluez can give you proper solution.
The Following User Says Thank You to akter_bd For This Useful Post:
Old 02-16-2012, 13:52   #4 (permalink)
contract's Avatar
Member: 671937
Sonork: 100.1613181
Thanks Meter: 94
Arrow
or
or
sorry bro i dont understand what do you mean by "load PM or mark load RFBB from server"............???
THANKS & BR
Old 02-16-2012, 17:21   #5 (permalink)
rabirabi's Avatar
Member: 1061924
Sonork: 100.1612111
Thanks Meter: 95
>load pm 1&309
>click "repair sd"
>after a while a meaasage will appear select "NO'
>then click "Write"
thats all
The Following User Says Thank You to rabirabi For This Useful Post:
Old 02-16-2012, 17:38   #6 (permalink)
Member: 1700720
Thanks Meter: 19
Question
THANKS & BR
"load PM or mark load RFBB from server" mean what i have to do before do Press Repair SD or Press Super SD auth. am i have to load pm or do not load any pm just select load RFBB from server? if load pm i have to load full pm select or select only 1 & 309?
& there are three type of solution i found insearch so actually in these three type which one i will do for SECURITY_TEST failed!?
Old 02-16-2012, 17:43   #7 (permalink)
Member: 1700720
Thanks Meter: 19
Question
Originally Posted by rabirabi View Post
>load pm 1&309
>click "repair sd"
>then click "Write"
thats all
i do not have to mark load RFBB from server & i do not have to press Super SD auth?
Old 02-16-2012, 17:47   #8 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
or
or
bro. i think you are newbie so load RFBB from server means pm will be loaded from sx4 server & after (repair sd, super sd auth or pmm auth) as per your need, but no need to mark load RFBB from server as sx4 server is offline & HTI box is stanalone needs no sx4 server. load full pm means if you backup pm & erase for phone for some issue you have to load full & if only to repair security test failed (1, 309 only), so learn & help others.............
The Following 2 Users Say Thank You to .::ZUBER::. For This Useful Post:
Old 02-17-2012, 06:33   #9 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
just follow these steps if u r confused:
1. don't mark load rfbb from server
2. click repair sd, and wait for superdongle ok
3. when pop up menu shown and asked u to write from rfbb data from your folder, click YES
4. pm 1 & 309 will be written automatically.
1. mark load rfbb from server
2. click repair sd/super sd auth (different click but it is the same, to get your superdongle ok)
3. when pop up menu shown and asked u to write from rfbb data from your folder, click NO
4. then click write, pm 1 & 309 will be loaded from server automatically
4. click load from file (search pm file in your computer, full or just 1 & 309 is same) <<< some people do this as 1st step, just same
5. then click write
still confused??? i have no more to say then
ps: sometimes u need to put your smart card in mx dongle instead of hti (based on some cases)
good luck bro
br
The Following 3 Users Say Thank You to specta For This Useful Post:
Old 02-17-2012, 17:48   #10 (permalink)
Registered User
Member: 318237
Thanks Meter: 5
very very thx bro.
5800xm test ok..
Old 02-19-2012, 12:55   #11 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
- about missing RF-BB: all you need to do is to find the way how to write 1+309 by any auth.
- missing certain field on certificate also bring CS problem. recover cert / clone RPL is the solution.
- bad asic power will also bring CS problem.
you have to be sure what is the EXACT caused of the CS problem.
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Page generated in 0.22210 seconds with 9 queries
