03-06-2012, 18:14 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Bosnia
Member: 698071 Status: Offline Sonork: 100.1622915 Thanks Meter: 283 | mxkey 3.5 rev 1.8 shows error "solved" (ANSWERED) [err0] required OHCI(1.1)/EHCI(2.0)/xHCI(3.0) controller ! NEC 5-Port USB 2.0 PCI Card solve this problem.. Using device: HTI PLUS Flasher Interface Connection status: OHCI:HUB:USB 2.00 Full-speed Interface: MXBOX/HTI (Powered by MXKEY) OTP ID: 430B1801CA09505307054B4C070000F5 Boot ver: 01.09, Box SN: 01003xxx FW version: 00.50 HTI PLUS Flasher Interface ready. Using device: HTI Flasher Interface (WinUSB) Connection status: OHCI:HUB:USB 2.00 Full-speed Interface: MXBOX/HTI (Powered by MXKEY) OTP ID: 17130A0AA00C4E531F17634B000000F5 Boot ver: 00.07, Box SN: 00000xxx FW version: 00.50 HTI Flasher Interface (WinUSB) ready. Thank you for watch.... br. sajohaker |
03-06-2012, 20:03 | #2 (permalink) |
No Life Poster Join Date: Apr 2010 Location: lagos nigeria
Member: 1278793 Status: Offline Thanks Meter: 68 | i have the same problem but dont understand above any one with solution to this Using device: HTI Flasher Interface (WinUSB) Connection status: UHCI:HUB:USB 2.00 Full-speed WARNING: Device drivers might not work properly ! [err0] required OHCI(1.1)/EHCI(2.0)/xHCI(3.0) controller ! Interface: MXBOX/HTI (Powered by MXKEY) OTP ID: 361C0C01680C505370DF404C000000F5 Boot ver: 00.07, Box SN: 0000CED1 FW version: 00.50 HTI Flasher Interface (WinUSB) ready. |
03-06-2012, 20:33 | #3 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, you can proceed your job as usual. Quote:
will be better if you can eliminate this notification. - try other USB port, also it must be plugged directly use no hub. | |
The Following User Says Thank You to gbluez For This Useful Post: |
03-19-2012, 09:26 | #4 (permalink) |
Freak Poster Join Date: May 2010
Member: 1308472 Status: Offline Sonork: mohd_nadeem231 Thanks Meter: 10 | Using device: HTI Flasher Interface (WinUSB) Connection status: UHCI:HUB:USB 2.00 Full-speed WARNING: Device drivers might not work properly ! [err0] required OHCI(1.1)/EHCI(2.0)/xHCI(3.0) controller ! Interface: MXBOX/HTI (Powered by MXKEY) OTP ID: 2A050301680C5053D30B404C020000F5 Boot ver: 00.07, Box SN: 00011FAD FW version: 00.50 HTI Flasher Interface (WinUSB) ready. |
03-19-2012, 12:04 | #5 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. already answered by gluez in above post, then also if you want to remove this warning, make a alteration with your PC motherboard with converting USB chipset from USB2 to USB3 or buy external USB3 adaptor. |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
