04-17-2010, 08:16 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Age: 44
Member: 889422 Status: Offline Thanks Meter: 182 | Alim sb see you Bootloader not resposting,mostly Ram problam Library version: 1.0.0.8009(15-04-2010), 1.0.0.12756(15-04-2010) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 BootLoader not responding, mostly RAM problem |
04-18-2010, 07:29 | #2 (permalink) |
Member: 889422 Status: Offline Thanks Meter: 182 | then flash for dct4 this err Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7920(18-03-2010), 1.0.0.12651(18-03-2010) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 BootLoader not responding, mostly RAM problem ! Processing file: rh93_06.400 as MCU [DCT4,DCT4 ALGORITHM] size: 1.89 MB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 BootLoader not responding, mostly RAM problem ! flashing terminated ! Flashing terminated with error(s) in 1 min 50.156 s RX Buffer: F372 |
04-18-2010, 08:42 | #4 (permalink) | |
Freak Poster Join Date: May 2008 Location: The Time Has Come....
Member: 765331 Status: Offline Thanks Meter: 78 | Quote:
press power on button when software stuck on sending bootloader i tested it 100% working with ufs interface.... | |
The Following User Says Thank You to deann For This Useful Post: |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Help::: NK 6130 (702) pay as you go | CMLC | Wanted Products | 0 | 08-14-1999 22:13 |
