Old 06-23-2010, 20:17   #1 (permalink)
akashrana_sky's Avatar
Member: 1220933
Sonork: 100.1590184
Thanks Meter: 471
all security test failed 100% solution! (TIPS) (ANSWERED)
Many people posted in this forum about security test failed !
we know that_______
when come security test failed ______
solution_____
1. super sd auth or pmm auth __than write good or modified pm ( must need pm 1 & 309)
or, 2. sd repair ___ super sd auth or pmm auth ____ than write good or modified pm ( must need pm 1 & 309)
My question ______
when we not success by up system
than what can we do for repair security test failed?
yes! we have this solution______
1. first backup rpl ( go > imei and security tab > imei rebuild > backup rpl)
2. erase old pm ( go > pm tab > erase )
3. Reset npc data ( go> imei and security tab> reset NPC data)( must backup rpl before do this)
4. Erase pm again (go > pm tab > erase )
5.Write rpl from backup ( go > imei and security tab > imei rebuild > restore imei)
6. go pm tab > super sd auth or pmm auth > than write good or modified pm ( must need pm 1 & 309)
7. erase pm again
8. Recover CERT ( go>imei and security tab> imei rebuild > recover cert)
9. give full factory reset
your phone must come back from security test failed
it is 100% tasted by me.
Don't forget to press thanks button !
The Following 30 Users Say Thank You to akashrana_sky For This Useful Post:
Old 06-23-2010, 20:27   #2 (permalink)
unicomtogo's Avatar
Member: 660737
Thanks Meter: 105
we know that_______
solution_____
My question ______
7. erase pm again
a thread about security test fail was posted already in this forum by Mr Hasnain. so useful
The Following 4 Users Say Thank You to unicomtogo For This Useful Post:
Old 06-23-2010, 20:41   #3 (permalink)
Member: 1220933
Sonork: 100.1590184
Thanks Meter: 471
i don't see this by search______
but it is my real and own!
thanks of replay!
The Following 3 Users Say Thank You to akashrana_sky For This Useful Post:
Old 06-23-2010, 20:43   #4 (permalink)
dil7689's Avatar
Member: 1080396
Thanks Meter: 1,661
thanks to post
good job
The Following 2 Users Say Thank You to dil7689 For This Useful Post:
Old 07-02-2010, 09:19   #5 (permalink)
Member: 1309734
Sonork: adnanishaque_korai
Thanks Meter: 2
lots of thanks
if this u not post this im gonig to die lots lots and lots of thanks
The Following User Says Thank You to kamrancool For This Useful Post:
Old 07-02-2010, 10:11   #6 (permalink)
Member: 1128573
Thanks Meter: 242
yes br. this is old story but always new for new users. of course very good job akashrana. many thanks.
thanks
mahir ashab
Old 07-02-2010, 16:25   #7 (permalink)
Member: 1243993
Sonork: +6287846666699
Thanks Meter: 12
thanks.....bigboss......
Old 07-02-2010, 16:36   #8 (permalink)
Member: 629228
Thanks Meter: 17
great job..thxxxxxxxx
The Following User Says Thank You to naurah For This Useful Post:
Old 07-03-2010, 10:53   #9 (permalink)
Member: 107987
Sonork: 1575070
Thanks Meter: 14
tested & work 10000000000000000000000000%
The Following User Says Thank You to joker1222000 For This Useful Post:
Old 07-03-2010, 13:03   #10 (permalink)
Member: 107853
Nokia 3120c-1c RM-364
Begin Certificate Request ...
[InternalErrorFault] CERT [0565888] data not found in database (case id=0xCE02)
what now...? wait..?
The Following User Says Thank You to sagi2 For This Useful Post:
Old 07-03-2010, 13:08   #11 (permalink)
Member: 649043
Thanks Meter: 18
thanks brother for good solution
The Following User Says Thank You to delwar_us For This Useful Post:
Old 07-08-2010, 08:17   #12 (permalink)
harisa's Avatar
Member: 81821
Thanks Meter: 14
SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
Product: V 07.20 05-10-09 RM-243 (c) Nokia
ApeCoreSw: 07.20
Using cached productData[145000105B5E0058A5C0577980BD3FC057D0586E] ...
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized !
Writing PM from Node ...
Section: 1
- Key: 0, size 114 bytes written.
- Key: 1, size 4 bytes written.
- Key: 2, size 98 bytes written.
- Key: 4, size 110 bytes written.
- Key: 5, size 4 bytes written.
- Key: 6, size 98 bytes written.
- Key: 8, size 110 bytes written.
- Key: 13, size 98 bytes written.
- Key: 15, size 4 bytes written.
- Key: 16, size 98 bytes written.
- Key: 18, size 98 bytes written.
- Key: 20, size 98 bytes written.
- Key: 22, size 16 bytes written.
- Key: 23, size 4 bytes written.
- Key: 24, size 84 bytes written.
- Key: 25, size 4 bytes written.
- Key: 26, size 110 bytes written.
- Key: 27, size 4 bytes written.
- Key: 28, size 98 bytes written.
- Key: 29, size 10 bytes written.
- Key: 31, size 98 bytes written.
- Key: 33, size 36 bytes written.
- Key: 34, size 80 bytes written.
- Key: 40, size 16 bytes written.
- Key: 41, size 182 bytes written.
- Key: 42, size 4 bytes written.
- Key: 43, size 36 bytes written.
Warning: failed to write 1 - 44 (182 bytes)
- Key: 46, size 64 bytes written.
Section: 309
- Key: 0, size 4 bytes written.
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 4, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 12 bytes written.
- Key: 8, size 12 bytes written.
- Key: 17, size 12 bytes written.
Completed in 2.875 s
Section: 1
Section: 309
Completed in 2.844 s
Section: 1
Section: 309
Completed in 2.906 s
how to repair warning failed to write 1-44[182 bytes]
Old 07-08-2010, 10:54   #13 (permalink)
A-H-T's Avatar
Member: 36394
Thanks Meter: 250
will try soon and post feedback
wbr.
Old 07-15-2010, 08:32   #14 (permalink)
Member: 172261
Thanks Meter: 364
mine is superdongle invalid, after repair sd become security test failed.
i follow method sucess fix security test failed but now back to superdongle invalid
Old 07-15-2010, 08:50   #15 (permalink)
defrianto's Avatar
Member: 588260
Thanks Meter: 34
thanks brother for good solution............
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-10-2014 12:35
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
Page generated in 0.28906 seconds with 9 queries
