12-01-2010, 12:12 | #1 (permalink) |
Junior Member Join Date: Jan 2008 Location: iran
Member: 678617 Status: Offline Thanks Meter: 2 | c1-00 RM-689 dead after flash i flashed this phone for upgrade and change language and all thing was ok and flash process done but in the end when phone must be set in local mode i recived an error ; phone not responding . and after than when i try to turn the phone on it doesnt turn on. my phone frimwar was 2.51 and i flashed it with 3.00 can any one help me? thanks |
12-01-2010, 12:22 | #2 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
12-01-2010, 12:45 | #3 (permalink) | |
Insane Poster Join Date: Oct 2006
Member: 367355 Status: Offline Thanks Meter: 17 | Quote:
The Following User Says Thank You to NARESTAN For This Useful Post: |
01-27-2011, 09:23 | #4 (permalink) |
Junior Member Join Date: Apr 2010 Location: P.U.R.W.A.K.A.R.T.A
Member: 1286962 Status: Offline Thanks Meter: 5 | Same problem with me........ This is log flashing : Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9113(26-12-2010), 1.0.0.15152(26-12-2010) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU ID: A200341100 [X-GOLD 110] Sending Primary Boot Loader ...OK Changing baudrate to: 921600 Sending Secondary Boot Loader ...OK BootloaderString: SE0_091125 F11 Boot mode: CC EBL version: 10.13, Default_RAM_Bootloader Flash ID: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] Processing CODE:hw_s01_rm689_r03.000.fls from file rm689_003.000 Erasing area 0x00800000-0x00A0FFFE ...OK Programming ... Programming completed in 44.281 s Erasing area 0x00C60000-0x00EAFFFE ...OK Programming ... Programming completed in 39.313 s Erasing area 0x00FFC000-0x00FFFFFE ...OK Programming ... Programming completed in 0.031 s Checksum OK (0x6F44) Processing CUST:hw_s01_rm689_003.00me.fls from file rm689_003.00me Erasing area 0x00210000-0x0045FFFE ...OK Programming ... Programming completed in 39.625 s Checksum OK (0x5DAC) Processing CUST:hw_s01_rm6890_nai03.00me.fls from file rm6890_nai03.00me Erasing area 0x00EB0000-0x00F7FFFE ...OK Programming ... Programming completed in 6.531 s Checksum OK (0x7C9B) Flashing completed in 3 min 1.765 s Phone not responding ! |
01-28-2011, 03:49 | #7 (permalink) |
Freak Poster Join Date: Dec 2009
Member: 1188155 Status: Offline Thanks Meter: 13 | the problem is the same, mxkey cant finish the flash sucessfully on new sl3, i had 2 n97 dead that before flashing work perfectrly the unique solution is flash with other box such as mtbox. But you can probe select the usb rom on interface, and try FLASH, probably can revive. you can prove select a diferent loader, go to setting uncheck autoloader, and select other loader |
01-28-2011, 03:49 | #8 (permalink) |
01-28-2011, 08:46 | #9 (permalink) | |
Member: 1286962 Status: Offline Thanks Meter: 5 | Quote:
But on my case this is DCT4+ generation Sir not BB5. Alhamdulilah on my case now fix with MX Key Sir... Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9113(26-12-2010), 1.0.0.15152(26-12-2010) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU ID: A200341100 [X-GOLD 110] Sending Primary Boot Loader ...OK Changing baudrate to: 921600 Sending Secondary Boot Loader ...OK BootloaderString: ÓûLjTs¾«`Boot mode: CC EBL version: 10.13, Default_RAM_Bootloader Flash ID: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] Processing CODE:hw_s01_rm689_r02.510.fls from file rm689_002.510 Erasing area 0x00800000-0x00A0FFFE ...OK Programming ... Programming completed in 49.125 s Erasing area 0x00C60000-0x00EAFFFE ...OK Programming ... Programming completed in 52.047 s Erasing area 0x00FFC000-0x00FFFFFE ...OK Programming ... Programming completed in 0.047 s Checksum OK (0xF57A) Processing CUST:hw_s01_rm689_002.51me.fls from file rm689_002.51me Erasing area 0x00210000-0x0045FFFE ...OK Programming ... Programming completed in 42.484 s Checksum OK (0xCA7C) Processing CUST:hw_s01_rm6890_nai02.51me.fls from file rm6890_nai02.51me Erasing area 0x00EB0000-0x00F7FFFE ...OK Programming ... Programming completed in 7.062 s Checksum OK (0x80DA) Flashing completed in 3 min 22.906 s Phone Type: RM-689 SW Version: V 02.51 29-07-10 RM-689 (c) Nokia Imei plain: 35432404791447-4 Product Code: 059B340 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: ME Language Pack: - not available. Imei net: 35432404791447 Version: Provider: GSM Test Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN | |
The Following User Says Thank You to NTC_tea For This Useful Post: |
02-14-2011, 08:31 | #10 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Dadu Sindh Pakistan Age: 37
Member: 1322713 Status: Offline Sonork: 100.1663786 Thanks Meter: 254 | dear how can i flash c1-01 on mx key with usb cable when i flash it show this error plz help me... Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2E9F0A3 WriteDevice failed: Failed to read/write device |
The Following User Says Thank You to lucky2010 For This Useful Post: |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
