12-27-2011, 12:51 | #1 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Nepal
Member: 1061924 Status: Offline Sonork: 100.1612111 Thanks Meter: 95 | Amazing problem in mx box (CLOSED - RULES) BB5 fbus & usb flashing is 100% ok i also changed usb cable to original one..the same mobile is booting in ufs..i m saying about working phone here.. scan works good in all dct4 Phone type: RH-99 SW version: V 6.00 30-09-09 RH-99 (c) NMP Imei plain: 35955301985911-0 Product code: 0546861 Cellular system: GSM ASIC ID: 0x2292, type: 11 Ppm Id: MG Language Pack: English,Hindi,Marathi Master code: 4577705331 Imei net: 35955301985911 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN but same mobile bus check error..logs....... MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: xxxxxxx Using device: HTI, FW ver: 00.50, SN: xxxxxxxx Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13682(17-12-2011) ASIC ID: 0x2292 [UPPCosto ver: 1.3] Error sending bootloader ! i m realy confused here...on the other hand mxbox works for nokia 6070..logs..... MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: xxxxxx Using device: HTI, FW ver: 00.50, SN: xxxxxxxxxxx Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13682(17-12-2011) ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8804 [ST 58LR128U,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 009073AC:2984DA60 ASIC type: 2 UEM Imei: 35627801200952 Flash Imei: 35627801200952 MasterCode: 1556666133 RPL saved to "C:\mobileEx\3.5\data\backup\35627801200952_132498 2244_BACK.rpl" Phone type: RM-166 (Nokia 6070) SW version: V 04.22 24-05-07 RM-166 (c) Nokia. Imei plain: 35627801200952-0 Imei OTP: 35627801200952 Cellular system: GSM ASIC ID: 0x2142, type: 2 Ppm Id: MR Language Pack: English,Chinese S,Chinese T (China) Master code: 2646305437 Security code: 12345 Imei net: 35627801200952 Version: SIMLOCK SERVER VERSION 58 Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN i m facing same problem in 1110,1600,1202,1200,1208 etc models.... plz help me...... |
12-27-2011, 12:56 | #2 (permalink) |
Member: 1061924 Status: Offline Sonork: 100.1612111 Thanks Meter: 95 | one thing i forgot to say..my box was working perfect till 1.5 version... i got this problem after installing 1.6 i also tried in another computer but no luck...plz help me guys |
12-27-2011, 14:06 | #4 (permalink) | |
Member: 1061924 Status: Offline Sonork: 100.1612111 Thanks Meter: 95 | Quote:
i understand what u mean to say..as i said >first uninstalled mxkey suite >deleted mobilEX folder then restarted >installed 3.5 ver 1.6 & signed application then update HTI & synochorised file but also not solved..other box working fine..remember i got this problem after updated to rev 1.6 | |
12-27-2011, 14:21 | #5 (permalink) |
No Life Poster Join Date: Oct 2010 Location: Poland (3 City)
Member: 1413902 Status: Offline Sonork: 100.1611698 Thanks Meter: 143 | uninstall 3.5 v 1.6 plug hti to usb go to control panel --> device manager and uninstall hti driver unplug hti from usb delete folder mobileEx install 3.5 v 1.5 plug hti to usb install driver from mobileEx 3.5 v 1.5 folder |
12-27-2011, 19:34 | #6 (permalink) |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,944 | @ thread starter Here you edited the log: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: xxxxxx Using device: HTI, FW ver: 00.50, SN: xxxxxxxxxxx Here are the rules for posting in our section: http://forum.gsmhosting.com/vbb/f613...ection-967354/ 5. If you need help, post your problem with most accurate description: - post logs and screen shots (do not edit logs in any way) - post phone model and phone status before you used mxkey - also remember to post what version of mxkey software you used and what interface. YOUR THREAD CAN BE CLOSED/DELETED W/O ANY NOTIFICATION Closed. Learn to respect this rules if you need our team support. BR, Manole |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
Lock 2 in nokia 51xx/61xx | Pablo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-31-1999 04:35 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
