12-20-2010, 18:40 | #1 (permalink) |
Banned Join Date: Dec 2008
Member: 916579 Status: Offline Sonork: 7280072 Thanks Meter: 23 | any body help me?plz plz plz |
12-20-2010, 23:56 | #2 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Bosnia
Member: 698071 Status: Offline Sonork: 100.1622915 Thanks Meter: 283 | use :dead usb full batery .usb cable and good charger download latest firmware and install in mx-key use :dead usb and nokia tool model:you phone market:you phone patch:you phone and pres flash Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button(if flashing doesnt start automatically) X2 Library version: 1.0.0.8986(19-10-2010), 1.0.0.14852(19-10-2010) Processing MCU file: rm618__04.90.mcusw [BB5,XSR 1.6] size: 26.74 MB Supported Ids: 2200050920030000, 22000509200C0000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2D211F22 CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: -] CMT EM0 ID: 00005361 CMT PUBLIC ID: 0000000000AA32927E178FB7D1A38D2BFFCBA7B4 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: bcm21351_usb2nd.fg [BB5] version: 10.10.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Secondary boot loaded. FlashID0: 0020 0030 - 0000 0131 [ST NAND-1G] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0020 0030 - 0000 0131 [ST NAND-1G] type: MuxOneNAND,CMT Loading CMT update server data Algorithm: bcm21351_xsr16_usbalg.fg [XSR 1.6] version: 10.6.1 revision: 2.1 size: 0x9942E Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Pooling for ADL device OK. Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2D211F22 Verifying communication to device OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.4\data\backup\BB5_3526990431396 7_CE RT.rpl" CMT PAPUBKEYS HASH: E9700989029D9E899915F781B1582048E042A738 Storing certificate [NPC, CCC, HWC, R&D] ... Partitioning.... Partitioning complete Erase size: 32.88 MB Flash programming ... CMT PAPUBKEYS: E9700989029D9E899915F781B1582048E042A738 (RAP Certificate v1 237) written. Programming completed in 9.781 s Processing PPM file: rm618__04.90.ppm_d [BB5,XSR 1.6] size: 6.84 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 8.00 MB Flash programming ... Programming completed in 2.329 s Processing CNT file: rm618__04.90.image_d_0595057_005 [BB5,XSR 1.6] size: 17.73 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 76.31 MB Flash programming ... Programming completed in 6.672 s Total time for flashing process(boot+erase+write) was 35.453 s |
12-21-2010, 00:23 | #3 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, - Select: Nokia USB ROM as interface make sure you have installed "Nokia_Connectivity_Cable_Driver" that placed inside C:\mobileEx\3.4\data\drivers\nokia the rest, all said well by user sajohaker. thank you sajohaker. BR |
12-21-2010, 09:00 | #4 (permalink) |
Member: 916579 Status: Offline Sonork: 7280072 Thanks Meter: 23 | usb flashing problam................. [BB5,XSR 1.6] size: 26.74 MB Supported Ids: 2200050920030000, 22000509200C0000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 3525C8E1 CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: -] CMT EM0 ID: 00005361 CMT PUBLIC ID: 0000000000AE1B3D60E94D9D4B9CD0731AF26DB9 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: bcm21351_usb2nd.fg [BB5] version: 10.10.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Secondary boot loaded. FlashID0: 0020 0030 - 0000 0131 [ST NAND-1G] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0020 0030 - 0000 0131 [ST NAND-1G] type: MuxOneNAND,CMT Loading CMT update server data Algorithm: bcm21351_xsr16_usbalg.fg [XSR 1.6] version: 10.6.1 revision: 2.1 size: 0x9942E Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Pooling for ADL device OK. Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 3525C8E1 Verifying communication to device OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Rpl(Certificate) backup already exist (C:\mobileEx\3.4\data\backup\BB5_35485404227350_CE RT.rpl). CMT PAPUBKEYS HASH: E9700989029D9E899915F781B1582048E042A738 Storing certificate [NPC, CCC, HWC, R&D] ... Partitioning.... Partitioning complete Erase size: 32.88 MB Flash programming ... CMT PAPUBKEYS: E9700989029D9E899915F781B1582048E042A738 (RAP Certificate v1 237) written. Programming completed in 7.563 s Processing PPM file: rm618__04.90.ppm_ml [BB5,XSR 1.6] size: 6.50 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 8.00 MB Flash programming ... Programming completed in 1.906 s Processing CNT file: rm618__04.90.image_d_059B9B6_003 [BB5,XSR 1.6] size: 18.00 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 76.31 MB Flash programming ... Programming completed in 5.312 s Total time for flashing process(boot+erase+write) was 44.578 s Pooling for ADL device ... Timeout, no usb device found. Flashing completed in 1 min 56.047 s set is not ON.......... |
12-21-2010, 09:20 | #7 (permalink) |
Member: 916579 Status: Offline Sonork: 7280072 Thanks Meter: 23 | MCU Flash file: D:\Program Files\Common Files\Nokia\DataPackage\Products\RM-618\rm618__04.90.mcusw PPM Flash file: D:\Program Files\Common Files\Nokia\DataPackage\Products\RM-618\rm618__04.90.ppm_mi CNT Flash file: D:\Program Files\Common Files\Nokia\DataPackage\Products\RM-618 but set is not on. |
12-22-2010, 16:31 | #11 (permalink) |
Member: 698071 Status: Offline Sonork: 100.1622915 Thanks Meter: 283 | before each procedure .. Connect phone to pc driver install. I am using nokia drivers who are in x: \ mobileEx \ 3.4 \ data \ drivers \ nokia ... and nokia ovi suite. attention to the firmware . use latest firmware. So far I have about 10 pieces .. I had no problems br. sajohaker |
12-23-2010, 06:42 | #14 (permalink) | |
Freak Poster Join Date: Feb 2008 Location: royal mobiles kotla
Member: 714116 Status: Offline Thanks Meter: 48 | Quote:
1. rm618__04.90.mcusw 2.rm618__04.90. ppm_meac 3.rm618__04.90.image meac i think u r not selecting same ppm and image | |
