any buddy tell me its hardware or software problem HELLP to all my frnd i just want to know..its hardware or software problem in my nokia 6300 show contact servis problem here is bus check log hone Type: RM-217 (Nokia 6300) SW Version: V 05.50 14-08-07 RM-217 (c) Nokia. Imei plain: 35981101663620-8 Product Code: 0537630 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359811016636208 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Here is self tests log.. Phone Type: RM-217 SW version: V 05.50 14-08-07 RM-217 (c) Nokia. ID Test name Startup Result 3 EAR_DATA_LOOP Y PASSED(00) 12 SIM_CLK_LOOP Y PASSED(00) 13 SIM_IO_CTRL_LOOP Y PASSED(00) 15 SLEEP_X_LOOP Y !FAILED(01) 46 UEM_CBUS_IF Y PASSED(00) 7 KEYBOARD_STUCK N !NOT EXECUTED(03) 22 CAMERA_IF N !NOT EXECUTED(03) 20 BACKUP_BATT N !NOT EXECUTED(03) 21 LPRF_IF N !NOT EXECUTED(03) 44 LPRF_AUDIO_LINES N !NOT EXECUTED(03) 2 CURRENT_CONS N !NOT EXECUTED(03) 42 RADIO Y PASSED(00) 69 BACKLIGHT Y PASSED(00) 33 SIM_LOCK N !NOT EXECUTED(03) 93 SECURITY N !NOT EXECUTED(03) 71 BT_WAKEUP N !NOT EXECUTED(03) 96 HOOKINT N !NOT EXECUTED(03) 88 TAHVOINT Y PASSED(00) 56 SLEEPCLK_FREQ N !NOT EXECUTED(03) 101 BTEMP N !NOT EXECUTED(03) 107 BT_SLEEP_CLK N !NOT EXECUTED(03) 108 EXT_DEVICE N !NOT EXECUTED(03) 86 CDSP_RF_BB_IF N !NOT EXECUTED(03) 83 CDSP_RF_SUPPLY N !NOT EXECUTED(03) 85 CDSP_TX_IQ N !NOT EXECUTED(03) 74 CDSP_TXC_DATA N !NOT EXECUTED(03) 79 CDSP_RX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03) 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) |
Bro; no doubt!! it's hardware issue. maybe u'r problem will be fixed by changing tahvo ic.. try and post result.. |
brother if you have screen short then upload the screen short you can help million of people . i ll face this problem many times . |
Try to flash first higher version use ver 7.30 and tick full factory after flash! Br, Mister G |
hello my freind , me to I have some problem , any help? |
frist flash higer versin and full default not work clean and lite rehat .................................................. ................................. tahvo ic red square http://img51.imageshack.us/img51/1528/6300.jpg br . sajo haker |
try this how to solve bb5 contact service ? I had my bb5 6300 so i did the following intstruction now my phone is 100% ok here ie the solution (1)first make backup (2) read pm to 0 to 500 (3) erase it with bb5 erase file (4) full flash the mobile with new version note Bakc up is use for some serius error if sp data currupted than we can easly write back up data to recover the phone again |
see sajohaker's post for solution |
