Old 05-06-2010, 13:00   #1 (permalink)
Master Software's Avatar
Member: 1149013
Thanks Meter: 247
Question MXKEY v3.4 revision 1.0 usb flash this version nokia 5800 imei plan 123456654321?
bfore flash imei is ok and working fine i flash it thats resion is bt not
not working i flash it with new version my phone gone in big problem
LOGs here
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
Processing file: RM-356_40.0.005_prd.core.C00 as MCU
[BB5,XSR 1.5] size: 105.66 MB
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable,Battery back to device.
Insert Charger or Press phone's power button
Waiting for USB device ...
[ADL] Pooling for ADL device
[ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2C0D9FF
RAP SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
RAP EM0 ID: 00000296
RAP EM1 ID: 00000B22
RAP PUBLIC ID: 15700014917100525280C0EA0BA5E315278F8A05
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
RAP ROM ID: 4B9B75103E691FF8
[ADL] Flashing CMT Update Server Data, ULO: 0x3B80 bytes
[ADL] Update Server code succesfully sent to phone.
[ADL] Flashing CMT Update Server Data, XSR: 0x2BAB45 bytes
[ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 225E01B2
[ADL] Verifying communication to device OK.
Partitioning....
Partitioning complete
Erase size: 158.19 MB
Flash programming ...
CMT PAPUBKEYS: 76A20187051C30162EE91C77AE5E6011F5F1BA61 (RAP Certificate 106 v1) written.
Programming completed in 1 min 52.515 s
Processing file: RM-356_40.0.005_prd.rofs2.V12 as PPM
[BB5,XSR 1.5] size: 20.20 MB
Erase size: 33.00 MB
Programming completed in 22.500 s
Processing file: RM-356_40.0.005_C01_prd.rofs3.fpsx as CNT
[BB5,XSR 1.5] size: 1.23 MB
Erase size: 13.00 MB
Programming completed in 1.391 s
[ADL] Device found: nmwcdc\Nokia GSM Phone USB Generic, ID: 1487A71
Flashing completed in 3 min 22.312 s
Phone Type: RM-356 (Nokia 5800 XpressMusic)
SW Version: V ICPR72_09w44.4 20-11-09 RM-356 (c) Nokia
Imei plain: 12345610654321-?
Product Code: 0559408
ApeCoreSw: V 40.0.005
Language Pack:
- not available.
SIMLOCK invalid!
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei plain is invalid !!!
SIMLOCK_DATA corrupted!
Total time to process is 3 min 25.828 s
USB Pooling failed, phone not found !
The Following 2 Users Say Thank You to Master Software For This Useful Post:
Old 05-06-2010, 13:08   #2 (permalink)
FaHaD_DePaR's Avatar
Member: 1257171
Thanks Meter: 86
O very big problem
u not make backup
Old 05-06-2010, 13:09   #3 (permalink)
Member: 823633
Thanks Meter: 1,705
bro any backup store u ?
nokia rpl but server is down
Old 05-06-2010, 13:10   #4 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
LOGs here
Partitioning....
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
downgrade will make this prblem
its not mx key problem
am flashed 5800 oday also
try high ver
Old 05-06-2010, 13:16   #5 (permalink)
nadim_mobiles's Avatar
Member: 867259
Sonork: 100.1595961
Thanks Meter: 215
now Nothing Will HAppen With Downgrade Or Upgrade Because You imei Plan is 123456789?
you need To BUy RPl
Old 05-06-2010, 13:16   #6 (permalink)
BENGAL TIGER's Avatar
Member: 1284099
Thanks Meter: 169
LOGs here
Partitioning....
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
just flash same version before have
and ofcourse same product code.this is important.
your set will ok.i think it was v31. am i right?
i have one set same problem after downgrade. it was v31 and t-mobile software.
and after imei 12345--- i flash again same version and same product code.my set ok but sd invalid.
no problem you can repair sd.
your log said you try with v40. i strongly suggest try original version.
try it. and post result.
The Following 3 Users Say Thank You to BENGAL TIGER For This Useful Post:
Old 05-06-2010, 13:27   #7 (permalink)
Gsm Mardan's Avatar
Member: 897494
Sonork: 100.1581481
Thanks Meter: 1,102
yes bro ur phone is sl3 ...flash the phone is with same version all become ok.....
I think with( show )provider ......
The Following 2 Users Say Thank You to Gsm Mardan For This Useful Post:
Old 05-06-2010, 13:27   #8 (permalink)
Gsm Mardan's Avatar
Member: 897494
Sonork: 100.1581481
Thanks Meter: 1,102
The Following User Says Thank You to Gsm Mardan For This Useful Post:
Old 05-06-2010, 13:33   #9 (permalink)
Member: 1149013
Thanks Meter: 247
ok bro good idea in try then i Post result
The Following User Says Thank You to Master Software For This Useful Post:
Old 05-06-2010, 13:36   #10 (permalink)
shahinahmed007's Avatar
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
yes you are 100% correct. master software try it and you will done.
many user not know about it.thanks for good post.
The Following User Says Thank You to shahinahmed007 For This Useful Post:
Old 05-06-2010, 15:08   #11 (permalink)
Member: 1149013
Thanks Meter: 247
thanks to all my problem solve with simple flash with version 40.00 on jaf box
br
imran
Old 07-24-2010, 07:16   #12 (permalink)
tashirao's Avatar
Member: 905094
Thanks Meter: 218
thanks master softwear
pleas also upload v40
to help others
thank you
Old 07-24-2010, 07:55   #13 (permalink)
tariq_h's Avatar
Member: 896307
Sonork: 0096
Thanks Meter: 231
Are sure bro to flash it with the same flash file RM-356?
This problem is not mxkey problem .it is result of wrong flash file
i had experienced once
Ithink that if u flash with the correct flash file,no problem with it
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.23775 seconds with 9 queries
