Old 06-07-2010, 12:11   #1 (permalink)
fflyx's Avatar
Member: 1208833
Sonork: 100.1590402
Thanks Meter: 142
Nokia N95 RM-160 APE bootloader not responding !
This is Scan:
Phone Type: RM-160 (Nokia N95)
SW Version: V 06wk41v57.1 24-04-08 RM-160 (c) Nokia
Imei plain: 35767601400135-4
Product Code: 0552415
Language Pack:
- not available.
Imei net: 357676014001354
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 7340400023927779
PROFILE_BITS: 8000000000000000
BLOCK 1: 1=LOCKED (MCC+MNC): 732123, DATA=732123
BLOCK 2: 1=LOCKED (MCC+MNC): 21407F, DATA=21407F
BLOCK 3: 1=LOCKED (MCC+MNC): 21402F, DATA=21402F
BLOCK 4: 1=LOCKED (MCC+MNC): 74000F, DATA=74000F
BLOCK 5: 1=LOCKED (MCC+MNC): 33403F, DATA=33403F
BLOCK 6: 1=LOCKED (MCC+MNC): 70503F, DATA=70503F
BLOCK 7: 1=LOCKED (MCC+MNC): 70604F, DATA=70604F
BLOCK 8: 1=LOCKED (MCC+MNC): 71402F, DATA=71402F
BLOCK 9: 1=LOCKED (MCC+MNC): 71030F, DATA=71030F
BLOCK 10: 1=LOCKED (MCC+MNC): 71606F, DATA=71606F
BLOCK 11: 1=LOCKED (MCC+MNC): 73002F, DATA=73002F
BLOCK 12: 1=LOCKED (MCC+MNC): 72207F, DATA=72207F
BLOCK 13: 1=LOCKED (MCC+MNC): 74807F, DATA=74807F
BLOCK 14: 1=LOCKED (MCC+MNC): 73404F, DATA=73404F
When i tried to flash:
Version from phone: 06wk41v57.1
Version from file: 35.2.001
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
Rpl backup already exist (C:\mobileEx\3.4\data\backup\BB5_35767601400135_BA CK.rpl).
Processing file: RM-160_35.2.001_PR.C0R as MCU
[BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG] size: 70.62 MB
Supported RAP Ids: 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103
Supported APE Ids: 24200705
APE Data :
SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2]
ASIC MODE ID: 00
PUBLIC ID: 29C4E401172ED110069AB5AB5696743AFD939B7B
ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1A4001164F6B0052177A75DF71075496D892FDD4
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: A8C1D6713E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89
SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00
Supported APE Ids: 24200703, 24200704, 24200705, 24200706
Flashing terminated with error(s) in 21.609 s
RX Buffer: F372
I change DCT4/BB5 Flash Loader Directory to 9.50.25.2 and when i tried to flash:
APE Data :
ASIC MODE ID: 00
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 9.50.0 revision: 2.0 size: 0x3B40
Supported RAP Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
New Protocol is not supported for the current interface (UFS_USB V2.8 (c) SarasSoft 2007.).
Flashing terminated with error(s) in 4.391 s
RX Buffer:
Please, what can i do? Thanks in advance
Old 07-07-2010, 02:26   #2 (permalink)
lynspyre's Avatar
Member: 786200
Thanks Meter: 19
I got same error with UFS3-Tornado Flasher.. But tried with JAF Flasher Interface (RED Type - Potato Flasher) and problem solved..
Version from phone: 20.0.062
Version from file: 35.0.002
Using device: POTATO BOX, FW ver: 01.B2
Rpl backup already exist (C:\mobileEx\3.4\data\backup\BB5_35898501029357_BA CK.rpl).
Processing file: RM-313_35.0.002_PR.C0R as MCU
[BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG] size: 72.16 MB
APE Data :
ASIC MODE ID: 00
PUBLIC ID: C04544386B39C817780712785A9D2EC4CE0E45D7
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 08D0010B3DAA00580B0A13409F773088674C29D7
ASIC MODE ID: 00
RAP PAPUBKEYS HASH: F8311F20A18CAD3B70A4F896C74DD8711E189EED
FlashID0: 00EC 0040 - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE
ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG
Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.57.0 revision: 0.0 size: 0x2E248
APE PAPUBKEYS HASH: F8311F20A18CAD3B70A4F896C74DD8711E189EED
Storing certificate ...OK
Partitioning ...OK
Erase size: 123.38 MB
CMT NOR area [00080000-007CF13D]
CMT NOR area [00000000-0005FFFF]
CMT NOR area [00880000-00EFFFFF]
APE NAND area [00000200-0000AFFF]
APE NAND area [0000B800-000AFFFF]
APE NAND area [00000000-00000FFF]
APE NAND area [0000D800-0000E9FF]
APE NAND area [00080000-000BFFFF]
APE NAND area [000E0000-0045FFFF]
APE NAND area [004C0000-0073FFFF]
APE NAND area [00A40000-0707FFFF]
erased in 30.469 s
Flash programming ...
CMT PAPUBKEYS: F8311F20A18CAD3B70A4F896C74DD8711E189EED (RAP Certificate 91 v1) written.
APE PAPUBKEYS: F8311F20A18CAD3B70A4F896C74DD8711E189EED (APE Certificate 91 v1) written.
Programming completed in 5 min 5.922 s
Processing file: RM-313_35.0.002_PR.v21 as PPM
[BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG] size: 11.85 MB
Supported RAP Ids: 4003192101021103, 400C192101021103, 4003192101002003, 400C192101002003, 400C192101011103, 4003192101011103, 4003192101031103, 400C192101031103
APE Data :
ASIC MODE ID: 00
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Partitioning ...OK
Erase size: 25.12 MB
APE NAND area [05760000-0707FFFF]
erased in 0.141 s
Programming completed in 49.672 s
Processing file: RM313_31.0.016_015_uda_4.fpsx as CNT
[BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG] size: 30.12 MB
Supported RAP Ids: 4003192101021103, 400C192101021103, 4003192101002003, 400C192101002003, 400C192101011103, 400C192101021105, 4003192101021105, 400C192101031103, 4003192101031103
APE Data :
ASIC MODE ID: 00
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 136.06 MB
APE SOS-USER
APE NAND area [07080000-0F87FFFF]
erased in 0.078 s
Programming completed in 5 min 20.687 s
Flashing completed in 12 min 18.468 s
Old 07-07-2010, 05:37   #3 (permalink)
Cheater -Don't Deal with him-
Member: 743601
Sonork: 83392409
Thanks Meter: 138
hi try to reheat flash iether its damage in high voltage of your platbox
Page generated in 0.18517 seconds with 9 queries
