Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, prob Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 07.21 05-11-08 RM-217 (c) Nokia. Using cached productData[26100214A0637E56671329160BCB9863B1131304] ... Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request help???? |
try also with JAF interface.... regards |
Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
Me too same problem anybody with solution? |
same here.... maybe the priblem is in the server. still contact retailer after write pm |
Me too same problem .is this problem of server or others |
mx team doese not have any solution for this bug dont wast time mx team doese not have any solution at all for this bug dont wast time find other solution or tool sory they kill only our creadit thanks |
brothar onley formate this |
STEP BY STEP 1-UNINSTALL MX-KEY 3.4 REV-1.0 2--DELETE FOLDER OF MX-KEY 3.4 (LOCATION-C:\MOBILEEx) 3--INSTALL MX-KEY SETUP 3.4 4--SIGN APPLICATION 5--SELECT OK PM 6--SUPER SD AUTH YOUR PROBLEM SOLVED |
use broad band line must be your problem solved 10000000000000000000% |
I think the problem is a problem of server coz SUPER SD AUTH works ok but Pm auth gives this massage no sx4 card found Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
