Old 12-30-2011, 07:05   #1 (permalink)
Member: 1276771
Thanks Meter: 33
n8 flashing error
i have a set n8
customer said it hang up alout
so i flashed with usb with infinity box
flashing going to be complete but at last stape it said
after flash not accepted
i tried many different firmware version
but same
here is bus check result of mxkey
MXKEY [FT SCR2000 0], SN: C0843E6E
Using device: HTI, FW ver: 00.24, SN: 0000DD76
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011)
CMT Data :
SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
EM0 ID: 00000C35
EM1 ID: 00000C30
PUBLIC ID: 1A7002042DD60344F90C5698CD6E244F9AA004F0
ASIC MODE ID: 00
ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
ROM ID: E693EF0DAC22615B
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.24.0 revision: 3.0 size: 0x3B40
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.24.0 revision: 3.0 size: 0xC6B13
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: D172C32473AE199B213465ABB3853246F9631231
Original Imei: 35698804445609
Original Product code: 0599464
Bluetooth ID: 782EEFC1DE47
SIMLOCK PA identifier:
[0] PA_SIMLOC30
mxkey flashing error
CMT Data :
EM0 ID: 00000C35
EM1 ID: 00000C30
ASIC MODE ID: 00
Processing MCU file: RM-596_024.001_79.92_prd.core.fpsx
[BB5,XSR 1.6] size: 122.50 MB
Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK
Partitioning ...OK
Erase size: 228.06 MB
CMT FLASH,MuxOneNAND area [00040000-0007FFFF]
CMT FLASH,MuxOneNAND area [000C0000-008BFFFF]
CMT FLASH,MuxOneNAND area [00DC0000-0E97FFFF]
Formating partition ...
Prog.status for Asic CMT ...
NAND: OK
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT SOS+PMML block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: D172C324 [RAP Certificate 103 v1] sent
CMT GENIO_INIT block sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT LDSP block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
NAND: OK
Programming completed in 5 min 58.156 s
Processing PPM file: RM-596_024.001_13.01_MEA_A_79.92_prd.rofs2.fpsx
[BB5,XSR 1.6] size: 47.28 MB
Erase size: 59.25 MB
CMT FLASH,MuxOneNAND area [09F40000-0DA7FFFF]
NAND: OK
CMT SOS+ROFS2 block sent
NAND: OK
Programming completed in 2 min 18.235 s
Processing PPM file: RM-596_024.001_C08.01_MEA_5_79.92_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 14.80 KB
Erase size: 15 MB
CMT FLASH,MuxOneNAND area [0DA80000-0E97FFFF]
NAND: OK
CMT SOS+ROFS3 block sent
NAND: OK
Programming completed in 0.437 s
Processing CNT file: RM596_APE_ONLY_ENO_11w15_v0.148.fpsx
[BB5,XSR 1.6] size: 4.05 MB
Erase size: 5 MB
CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF]
NAND: OK
CMT SOS*ENO block sent
NAND: OK
Programming completed in 12.219 s
Processing CNT file: RM-596_024.001_U08.01_79.92.uda.fpsx
[BB5,XSR 1.6] size: 80.77 MB
Erase size: 262 MB
CMT FLASH,MuxOneNAND area [0EA00000-1EFFFFFF]
NAND: OK
NAND: OK
Programming completed in 3 min 53.563 s
Total time for flashing process(boot+erase+write) was 12 min 37.922 s
at last step it gives error phone not respond reset manualyy??
what is the solution????
i have tried diffrent firmware and box and i tried with usb also the same error???
Old 12-30-2011, 08:55   #2 (permalink)
haixiang's Avatar
Member: 1538800
Sonork: Offline
Thanks Meter: 18
Use mobileEx 3.5 (rev1.6), and then update your HTI. If the problem is not resolved, please use the HTI FBUS
The Following User Says Thank You to haixiang For This Useful Post:
Old 12-30-2011, 09:01   #3 (permalink)
irfan_gsm's Avatar
Member: 709520
Thanks Meter: 275
exicute bb5 nand erase user area in quick fix tab
The Following User Says Thank You to irfan_gsm For This Useful Post:
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
error (1002) simlock3.dll winopen fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-28-1999 15:57
Page generated in 0.14706 seconds with 9 queries
