10-26-2012, 17:10 | #1 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1012165 Status: Offline Thanks Meter: 116 | blackberry 8520 when i put in d code,it does not accept it,and i have 5 attempts left pls i need ur solution. here is mx-key log below iMEI:35150505269.... MEP: MEP-06812.... SERVER->MXKEY - BLADE X at host2, agent version 1.2 revision 0.5 MEP2(Network): 5870143737061996 MEP3(Network Subset): 8032884399829812 MEP4(Service Provider,Active,0,10): 4324293802292053 MEP5(Corporate): 4827355384653049 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level ( 2 or 4) NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. BlackBerry Smartphone detached. |
10-26-2012, 17:21 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Check Phone keys working properly, Some time fails to this, as you cannot see what you typed, Attempt once again with lock level 2. BR, ZUBER |
