03-23-2010, 11:48 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: PT Age: 40
Member: 108180 Status: Offline Sonork: 100.106866 Thanks Meter: 381 | Bugs In 3.3 1.7 Fixed Using device: POTATO BOX, FW ver: 01.B4 Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Boot error: 00 F2 FF FF TX line remains low ! - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. BUS CHECK - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. ( phone Nokia 5310, also have try other phones ) Someone who have a few nokia 5310 can test please, and Mr Manole can u check it to.... Strange problem. Im Using Potato Interface, is working... not a Phone, cable or Potato interface... in older verseion works nice... Fix this bug.... B.r. guedes666 |
03-23-2010, 12:13 | #2 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | hope you read this !!! we advice MXKEY users: DO NOT UPDATE YOUR JAFBOX FIRMWARE !!! and still today i ADVICE SAME: DO NOT UPDATE YOUR POTATO (JAF) BOX with last JAF 1.98.65 and all other next updates. the mostly case is from Quote:
br, | |
03-23-2010, 12:31 | #3 (permalink) |
Member: 108180 Status: Offline Sonork: 100.106866 Thanks Meter: 381 | SCAN Phone Type: RM-303 (Nokia 5310 XpressMusic) SW Version: V 03.63 24-10-07 RM-303 (c) Nokia Imei plain: 35204402422861-3 Product Code: 0558572 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352044024228613 Version: SIMLOCK SERVER Provider: Vodafone / Yorn, Country: Portugal Counter: 0/3, 0/10 CONFIG_DATA: 2680100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 26801F, DATA=26801F BUS Check Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101013000 EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 19F00107085E0254FEA8A0CC79ED9602448F7736 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 3E96DE4212587183E5E16BB2C79692A53C19875D Original Imei: 35204402422861 Original Product code: 0558572 Bluetooth ID: 001F0052BF0D Phone Type: RM-303 (Nokia 5310 XpressMusic) SW Version: V 03.63 24-10-07 RM-303 (c) Nokia Imei plain: 35204402422861-3 Product Code: 0558572 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352044024228613 Version: SIMLOCK SERVER Provider: Vodafone / Yorn, Country: Portugal Counter: 0/3, 0/10 CONFIG_DATA: 2680100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 26801F, DATA=26801F |
03-23-2010, 12:49 | #4 (permalink) | |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | so , MXKEY soft is doesn't have BUG in that right Quote:
and please don't ask about when have good connection or fix bug on that BOX version coder work on it, please enjoy our last update br, | |
03-23-2010, 12:58 | #5 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: Irvinestown
Member: 719399 Status: Offline Thanks Meter: 228 | Quote:
If you have following error: Using device: JAF FLASHER INTERFACE Interface: POTATO BOX » BOX FW Version: 01.B2 » BOX Authentication ...failed! Error opening ! Last error: The handle is invalid (code: 6) JAF FLASHER INTERFACE disconnected. That means you are using latest MxKey v3.3 revision 1.7 with an JAF box with PATCHED firmware 01.B2 written inside (used Potato Firmware Updater v2.0). Latest release of MxKey solved JAF Box crypted Authentification used by Potato & Co. to "protect" their boxes to no more be able to be used with 3rd party softwares. Now MxKey v3.3 revision 1.7 support well Authentification with original JAF Box firmwares 01.B2 and 01.B4. So, to solve the error described here: The handle is invalid (code: 6) just download POTATO JAF Box Firmware Updater v4.0 from here: POTATO JAFBox Updater V4 and write any ORIGINAL firmware inside your JAF Box. To be able to use latest release with New Flash Protocol, is required to write Original Firmware 01.B4 BR, Manole | |
03-23-2010, 13:39 | #7 (permalink) | |
Junior Member Join Date: Oct 2007
Member: 615837 Status: Offline Thanks Meter: 0 | Quote:
in this thread:http://forum.gsmhosting.com/vbb/f550...de-6-a-955457/ If you have following error: Using device: JAF FLASHER INTERFACE Interface: POTATO BOX » BOX FW Version: 01.B2 » BOX Authentication ...failed! Error opening ! Last error: The handle is invalid (code: 6) JAF FLASHER INTERFACE disconnected. That means you are using latest MxKey v3.3 revision 1.7 with an JAF box with PATCHED firmware 01.B2 written inside (used Potato Firmware Updater v2.0). Latest release of MxKey solved JAF Box crypted Authentification used by Potato & Co. to "protect" their boxes to no more be able to be used with 3rd party softwares. Now MxKey v3.3 revision 1.7 support well Authentification with original JAF Box firmwares 01.B2 and 01.B4. So, to solve the error described here: The handle is invalid (code: 6) just download POTATO JAF Box Firmware Updater v4.0 from here: | |
03-23-2010, 13:43 | #8 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: U.S.A.
Member: 893209 Status: Offline Thanks Meter: 274 | Sir, HOW about DCT4+..Using UFS INTERFACE.. SCAN LOGS(no PROBLEM) Quote:
BUS CHK..... Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 BootLoader not responding, mostly RAM problem ! Try to CHANGE FLASH LOADER no luck SIR.. Br,. Rhyan777 | |
06-26-2010, 14:36 | #10 (permalink) |
Freak Poster Join Date: Sep 2009 Location: Sri Lanka
Member: 1109931 Status: Offline Sonork: Bongo Thanks Meter: 44 | Hello Sir. ! My JAF Box showing like this in MX Key Application. Using device: POTATO FLASHER INTERFACE Interface: POTATO BOX » BOX FW Version: 01.B1 » BOX Authentication ...OK. POTATO FLASHER INTERFACE ready. After connecting the nokia service tool & BUS CHECK, Its showing following ERROR Using device: POTATO BOX, FW ver: 01.B1 Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Unknown ID ! Error getting boot info ! Can you help me plz... |
mobile ex 3.3 rev 1.7 fixed stil have a problem | bharat_3013 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 83 | 04-18-2010 07:09 |
mx key new v 3.3 rev 1.7 fix cant flash dc4 | bharat_3013 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 03-24-2010 13:30 |
bug in mxkey 3.3.7 | ABOUSHADY | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 03-20-2010 18:20 |
when the bug in the cid52FUT will be fixed ? | patric | FuriousGold | 17 | 07-08-2008 07:13 |
bug in version 3.3.3??? | turca | Universalbox | 1 | 07-11-2007 12:41 |
