11-04-2012, 09:50 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 71
Member: 174094 Status: Offline Thanks Meter: 74 | c2-00 flash prob but phone not reboot in end of flsah any idea MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C085CB22 Using device: USB ROM and HTI, FW ver: 00.50, SN: 010007E1 Connection status: OHCI:HUB::USB 1.10 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.44 EBL version: Quantum_Bootloader_10.44_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Processing file: rm704__03.99.mcusw Downloading item CODE:rm704__03.99.mcusw_ebl_psi.fls, num block: 4, size: 26 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.625 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.468 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 3.219 s Erasing area 0x40280000-0x41B3FFFE ...OK Programming completed in 51.532 s Checksum verified (0x6C69) Processing file: rm704__03.99.ppm_m_a Downloading item CUSTackage_m_a.ppm_ebl_psi.fls, num block: 1, size: 3.30 MB Erasing area 0x41BC0000-0x41F0C73A ...OK Programming completed in 6.734 s Checksum verified (0x6D09) Processing file: rm704__03.99.image_m_a_magenta_059C1L6 Downloading item CUSTackage_m_a_magenta_059C1L6.imag , num block: 1, size: 10 MB Erasing area 0x421C0000-0x43E1FFFE ...OK Programming completed in 19.187 s Checksum verified (0x9B4F) Total time for flashing process(boot+erase+write) was 7 min 51.859 s Waiting for USB device removal ... Waiting for device boot up ... Phone not found, retrying ... Warning: Phone did not reboot to normal mode. |
