emilkawa | 05-05-2014 12:05 | Quote:
Originally Posted by .::ZUBER::.
(Post 10262473)
Bro.
I don't think this modified my edited PM will help,
But just extract this .rar file & try to write this PM,
Your Simlock section in your original backup PM is already damaged, so may be this will not help,
BTW write my PM & post result.
BR,
ZUBER | unfortunately the same after write your PM: Code:
MXKEY [FT SCR2000 0], SN: C080B930
Using device: USB ROM
Connection status: UHCI:HUB::USB 1.10 (Full-speed)
Driver: NMWCD, ver: 7.1.32.115
Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 337E2F2B
Device synchronized.
CPU: XGOLD 213
Using embedded SBL from MCU.
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.46
EBL version: Quantum_Bootloader_10.46_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 00EC 3012 - 23280002 [Samsung ]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Original IMEI: 35835005092441
RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD_35835005092441_back.RPL)
Processing file: rm724__08.87.mcusw
Downloading item CODE:rm724__08.87.mcusw_ebl_psi.fls, num block: 4, size: 25.50 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.955 s
Erasing area 0x40040000-0x4005FFFE ...OK
Programming completed in 0.452 s
Erasing area 0x40060000-0x4015FFFE ...OK
Programming completed in 1.800 s
Erasing area 0x40280000-0x41ABFFFE ...OK
Programming completed in 45.077 s
Checksum verified (0xB866)
Processing file: rm724__08.87.ppm_b
Downloading item CUST:package_b.ppm_ebl_psi.fls, num block: 1, size: 4.36 MB
Erasing area 0x41B40000-0x41F9B242 ...OK
Programming completed in 11.031 s
Checksum verified (0x8541)
Processing file: rm724__08.87.image_b_dgray_059F9X3
Downloading item CUST:package_b_dgray_059F9X3.image.fl , num block: 1, size: 14.75 MB
Erasing area 0x42240000-0x43E1FFFE ...OK
Programming completed in 42.306 s
Checksum verified (0x9C2D)
Total time for flashing process(boot+erase+write) was 5 min 26.822 s
Waiting for USB device removal ...
Waiting for device boot up ...
Device connected: nmwcdc\Nokia C2-05 USB Phonet, PORT_ID: 358350050924411
Verifying communication to device OK.
Phone type: RM-724 (C2-05)
SW version: V 08.87 17-10-12 RM-724 (c) Nokia
Imei plain: 35835005092441-1
Product code: 059G0M8
Language Pack:
- not available.
SIMLOCK_DATA corrupted!
Writing PM from Node ...
Section: 3
- Key: 0, size 2 bytes written.
Section: 4
- Key: 1, size 800 bytes written.
- Key: 3, size 10 bytes written.
- Key: 4, size 8 bytes written.
- Key: 5, size 8 bytes written.
- Key: 6, size 8 bytes written.
- Key: 9, size 5 bytes written.
- Key: 18, size 78 bytes written.
- Key: 19, size 4 bytes written.
- Key: 26, size 132 bytes written.
- Key: 28, size 2 bytes written.
Section: 8
- Key: 1, size 16 bytes written.
- Key: 2, size 16 bytes written.
- Key: 3, size 128 bytes written.
- Key: 4, size 128 bytes written.
- Key: 8, size 8 bytes written.
- Key: 9, size 8 bytes written.
- Key: 10, size 32 bytes written.
- Key: 11, size 4 bytes written.
- Key: 12, size 4 bytes written.
Section: 11
- Key: 0, size 4 bytes written.
- Key: 1, size 4 bytes written.
- Key: 2, size 4 bytes written.
- Key: 3, size 4 bytes written.
- Key: 4, size 241 bytes written.
Section: 13
- Key: 0, size 1 byte written.
- Key: 1, size 2 bytes written.
- Key: 2, size 1 byte written.
- Key: 3, size 2 bytes written.
- Key: 4, size 1 byte written.
- Key: 5, size 1 byte written.
- Key: 6, size 1 byte written.
- Key: 7, size 1 byte written.
- Key: 8, size 2 bytes written.
- Key: 9, size 1 byte written.
- Key: 10, size 1 byte written.
- Key: 11, size 48 bytes written.
- Key: 13, size 1 byte written.
- Key: 14, size 1 byte written.
- Key: 15, size 886 bytes written.
- Key: 16, size 2 bytes written.
- Key: 17, size 1 byte written.
- Key: 18, size 1 byte written.
- Key: 19, size 8 bytes written.
- Key: 20, size 1 byte written.
- Key: 21, size 1 byte written.
- Key: 22, size 1 byte written.
- Key: 23, size 1 byte written.
- Key: 24, size 1 byte written.
- Key: 25, size 2 bytes written.
- Key: 26, size 1 byte written.
- Key: 27, size 1 byte written.
- Key: 28, size 1 byte written.
- Key: 29, size 1 byte written.
- Key: 30, size 1 byte written.
- Key: 31, size 1 byte written.
- Key: 32, size 1 byte written.
- Key: 33, size 1 byte written.
- Key: 34, size 1 byte written.
- Key: 35, size 1 byte written.
- Key: 36, size 1 byte written.
- Key: 37, size 4 bytes written.
- Key: 38, size 1 byte written.
- Key: 39, size 1 byte written.
- Key: 40, size 1 byte written.
- Key: 41, size 1 byte written.
- Key: 42, size 4 bytes written.
- Key: 43, size 4 bytes written.
- Key: 44, size 1 byte written.
- Key: 45, size 4 bytes written.
- Key: 46, size 4 bytes written.
- Key: 47, size 1 byte written.
- Key: 48, size 4 bytes written.
- Key: 49, size 1 byte written.
- Key: 50, size 1 byte written.
- Key: 51, size 1 byte written.
- Key: 52, size 2 bytes written.
- Key: 53, size 4 bytes written.
- Key: 54, size 4 bytes written.
- Key: 55, size 1 byte written.
- Key: 56, size 1 byte written.
- Key: 57, size 1 byte written.
- Key: 58, size 2 bytes written.
- Key: 59, size 1 byte written.
- Key: 60, size 4 bytes written.
- Key: 61, size 4 bytes written.
- Key: 62, size 1 byte written.
- Key: 63, size 4 bytes written.
- Key: 64, size 4 bytes written.
- Key: 65, size 1 byte written.
- Key: 66, size 4 bytes written.
- Key: 67, size 4 bytes written.
- Key: 68, size 1 byte written.
- Key: 69, size 1 byte written.
- Key: 70, size 1 byte written.
- Key: 71, size 4 bytes written.
- Key: 72, size 4 bytes written.
- Key: 73, size 1 byte written.
- Key: 74, size 4 bytes written.
- Key: 75, size 2 bytes written.
- Key: 76, size 2 bytes written.
- Key: 77, size 2 bytes written.
- Key: 78, size 1 byte written.
- Key: 79, size 1 byte written.
- Key: 80, size 1 byte written.
- Key: 81, size 1 byte written.
- Key: 82, size 1 byte written.
- Key: 83, size 2 bytes written.
- Key: 84, size 1 byte written.
- Key: 85, size 4 bytes written.
- Key: 86, size 4 bytes written.
- Key: 87, size 2 bytes written.
- Key: 88, size 1 byte written.
- Key: 89, size 4 bytes written.
- Key: 90, size 4 bytes written.
- Key: 91, size 2 bytes written.
- Key: 92, size 1 byte written.
- Key: 93, size 4 bytes written.
- Key: 94, size 4 bytes written.
- Key: 95, size 2 bytes written.
- Key: 96, size 1 byte written.
- Key: 97, size 4 bytes written.
- Key: 98, size 4 bytes written.
- Key: 99, size 2 bytes written.
- Key: 100, size 4 bytes written.
- Key: 101, size 2 bytes written.
- Key: 102, size 1 byte written.
- Key: 103, size 4 bytes written.
- Key: 104, size 4 bytes written.
- Key: 105, size 4 bytes written.
- Key: 106, size 4 bytes written.
- Key: 107, size 4 bytes written.
- Key: 108, size 2 bytes written.
- Key: 109, size 4 bytes written.
- Key: 110, size 4 bytes written.
- Key: 111, size 4 bytes written.
- Key: 112, size 2 bytes written.
- Key: 113, size 4 bytes written.
- Key: 114, size 4 bytes written.
- Key: 115, size 1 byte written.
- Key: 116, size 1 byte written.
- Key: 117, size 1 byte written.
- Key: 118, size 4 bytes written.
- Key: 119, size 4 bytes written.
- Key: 120, size 1 byte written.
- Key: 121, size 1 byte written.
- Key: 122, size 1 byte written.
- Key: 123, size 8 bytes written.
- Key: 124, size 1 byte written.
- Key: 125, size 1 byte written.
- Key: 126, size 1 byte written.
- Key: 127, size 1 byte written.
- Key: 128, size 1 byte written.
- Key: 129, size 4 bytes written.
- Key: 130, size 4 bytes written.
- Key: 131, size 1 byte written.
- Key: 132, size 1 byte written.
- Key: 133, size 2 bytes written.
- Key: 134, size 1 byte written.
- Key: 135, size 2 bytes written.
- Key: 136, size 1 byte written.
- Key: 137, size 1 byte written.
- Key: 138, size 4 bytes written.
- Key: 139, size 4 bytes written.
- Key: 140, size 1 byte written.
- Key: 141, size 1 byte written.
- Key: 142, size 1 byte written.
- Key: 143, size 1 byte written.
- Key: 144, size 4 bytes written.
- Key: 145, size 8 bytes written.
- Key: 146, size 4 bytes written.
- Key: 147, size 4 bytes written.
- Key: 148, size 1 byte written.
- Key: 149, size 1 byte written.
- Key: 150, size 1 byte written.
- Key: 151, size 1 byte written.
- Key: 152, size 1 byte written.
- Key: 153, size 1 byte written.
- Key: 154, size 1 byte written.
- Key: 155, size 1 byte written.
- Key: 156, size 1 byte written.
- Key: 157, size 1 byte written.
- Key: 158, size 1 byte written.
- Key: 159, size 2 bytes written.
- Key: 160, size 2 bytes written.
- Key: 161, size 1 byte written.
- Key: 162, size 1 byte written.
- Key: 163, size 1 byte written.
- Key: 164, size 1 byte written.
- Key: 165, size 1 byte written.
- Key: 166, size 1 byte written.
Section: 24
Section: 42
- Key: 1, size 12 bytes written.
- Key: 2, size 36 bytes written.
- Key: 3, size 36 bytes written.
- Key: 4, size 36 bytes written.
- Key: 5, size 36 bytes written.
- Key: 6, size 36 bytes written.
- Key: 7, size 40 bytes written.
- Key: 8, size 40 bytes written.
- Key: 9, size 40 bytes written.
- Key: 10, size 40 bytes written.
- Key: 11, size 40 bytes written.
- Key: 12, size 40 bytes written.
- Key: 13, size 40 bytes written.
- Key: 14, size 40 bytes written.
- Key: 15, size 40 bytes written.
- Key: 16, size 40 bytes written.
- Key: 17, size 40 bytes written.
- Key: 18, size 40 bytes written.
- Key: 19, size 40 bytes written.
- Key: 20, size 40 bytes written.
- Key: 21, size 40 bytes written.
- Key: 22, size 40 bytes written.
- Key: 23, size 40 bytes written.
- Key: 24, size 40 bytes written.
- Key: 25, size 40 bytes written.
- Key: 26, size 40 bytes written.
Section: 49
Section: 54
Section: 96
- Key: 1, size 20 bytes written.
Section: 107
- Key: 0, size 21 bytes written.
- Key: 1, size 89 bytes written.
- Key: 2, size 69 bytes written.
- Key: 3, size 70 bytes written.
- Key: 25, size 136 bytes written.
- Key: 26, size 12 bytes written.
Section: 111
Section: 116
Section: 117
- Key: 5, size 10 bytes written.
- Key: 16, size 62 bytes written.
Section: 120
- Key: 0, size 78 bytes written.
- Key: 1, size 160 bytes written.
- Key: 2, size 130 bytes written.
- Key: 3, size 112 bytes written.
Section: 153
- Key: 0, size 68 bytes written.
- Key: 1, size 68 bytes written.
- Key: 2, size 68 bytes written.
- Key: 3, size 68 bytes written.
- Key: 4, size 68 bytes written.
- Key: 5, size 68 bytes written.
Section: 163
- Key: 0, size 8 bytes written.
Section: 193
- Key: 2, size 8 bytes written.
- Key: 3, size 32 bytes written.
- Key: 4, size 32 bytes written.
- Key: 9, size 64 bytes written.
Section: 202
Section: 217
- Key: 0, size 32 bytes written.
Section: 218
Section: 238
- Key: 1, size 1 byte written.
Section: 301
Section: 308
- Key: 3, size 1 byte written.
- Key: 8, size 1 byte written.
Section: 322
Section: 339
- Key: 0, size 511 bytes written.
- Key: 1, size 511 bytes written.
Section: 341
Warning: failed to write 341 - 4 (4518 bytes)
Section: 354
- Key: 0, size 15 bytes written.
Section: 355
Warning: failed to write 355 - 0 (12068 bytes)
Completed in 7.425 s sections 341 and 355 didn't write.
What can I do else?
Emilkawa |
