08-18-2013, 09:37 | #1 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1231601 Status: Offline Thanks Meter: 13 | c3-00 MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C0856E16 Using device: USB ROM and HTI, FW ver: 00.50, SN: 00005C74 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.84 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) Processing MCU file: rm614__08.70.mcusw [BB5,XSR 1.6] size: 27.92 MB Supported Ids: 2200050920030000, 22000509200C0000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3B52DF0E CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 00000000004ADA3BE1CE112D33F051CF70CF3D99 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3B52DF0E FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x178 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35792104987125_CE RT.rpl" CMT PAPUBKEYS HASH: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK Partitioning.... Partitioning complete Erase size: 33.88 MB CMT FLASH,MuxOneNAND area [00000000-0001FFFF] CMT FLASH,MuxOneNAND area [00020000-000203FF] CMT FLASH,MuxOneNAND area [00060000-012FFFFF] CMT FLASH,MuxOneNAND area [01300000-01DFFFFF] CMT FLASH,MuxOneNAND area [02600000-029FFFFF] Formating partition ... Flash programming ... CMT KEYS block sent CMT ADA block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 697F7477 [RAP Certificate v1 232] sent CMT UPDAPP block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 17.734 s Processing PPM file: rm614__08.70.ppm_f [BB5,XSR 1.6] size: 5.95 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 8 MB CMT FLASH,MuxOneNAND area [01E00000-025FFFFF] Flash programming ... Programming completed in 3.937 s Processing CNT file: rm614__08.70.image_f_0593950 [BB5,XSR 1.6] size: 13.28 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 75.31 MB CMT FLASH,MuxOneNAND area [02A00000-0753FFFF] Formating partition ... Flash programming ... Programming completed in 6.641 s Total time for flashing process(boot+erase+write) was 1 min 5.484 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3B52DF0E Waiting for USB device removal ...OK Waiting for USB device arrival ... Warning: Phone did not reboot to normal mode. [RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) ! can i fix thise help meeeeeeeeeeee |
08-18-2013, 18:05 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Your Module is not Updated, So please click Synchronize File for Update & repeat Flashing, Post reply if problem persist. BR, ZUBER |
08-19-2013, 09:44 | #4 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Phone not rebooting & you having Backup of Phone, So try to Erase Phone & again Flash it with Latest version Firmware of Product Code, Phone will reboot with corrupted IMEI & Simlock, Now restore IMEI will work for you, If still problem persist, then post reply with Buscheck & if possible Selftest Logs. BR, ZUBER |
08-19-2013, 11:11 | #5 (permalink) |
Member: 1231601 Status: Offline Thanks Meter: 13 | cant erase thise phone MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C0856E16 Using device: USB Phonet and HTI, FW ver: 00.50, SN: 00005C74 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: nmwcdnsuc, ver: 7.1.32.84 Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 00000000004ADA3BE1CE112D33F051CF70CF3D99 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 12.8.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 12.8.0 revision: 2.1 size: 0x99058 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3B52DF0E FUR: Adding Asic CMT as client OK. CMT FLASH,MuxOneNAND area [00000000-00FDFFFF] Erase size: 15.87 MB Error while erasing, Result: 0000000B010E00 , 0 Process failed ! http://rapidshare.com/files/3747609914/c3-00%201.JPG Last edited by gsusantha; 08-19-2013 at 11:18. |
