05-17-2012, 03:57 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ---- Age: 35
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | C5-00 only vibrate after flashing Code: MXKEY [MxKey Team HTI PLUS Flasher Interface 2], SN: Using device: USB Phonet and HTI, FW ver: 00.50, SN: Connection status: EHCI:HUB:USB 2.00 (High-speed) Driver: nmwcdc, ver: 7.1.32.75 Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012) Reading Important data ... NPC_DATA is empty. SIMLOCK_DATA saved OK SIMLOCK_KEY_DATA saved OK WMDRM_PD_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK LOCK120_DATA saved OK BB_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35484704298014_PM.rpl" Processing MCU file: rm645_071.005_prd.core.fpsx [BB5,XSR 1.6] size: 96.64 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Battery voltage: 3880 mV Phone type: RM-645 (Nokia C5-00) Product code: 0597838 SW version: 032.010 LanguagePkg version: 032.010032.010.11.01032.010.C00.01 Version from phone: 032.010 Version from file: 071.005 Waiting for USB device removal ... CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00000C35 CMT EM1 ID: 00000C30 CMT PUBLIC ID: 09200208A9A40344C0E5898255F9EB61366086EF CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 8A1F74D FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35484704298014_CERT.rpl" CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 170.06 MB CMT FLASH,MuxOneNAND area [00020000-0003FFFF] CMT FLASH,MuxOneNAND area [00060000-004DFFFF] CMT FLASH,MuxOneNAND area [008E0000-0AE3FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: D7D05CFC [RAP Certificate v1 249] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 18.750 s Processing PPM file: rm645_071.005_10.01_MEA_A_prd.rofs2.fpsx [BB5,XSR 1.6] size: 35.84 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 51 MB CMT FLASH,MuxOneNAND area [06D40000-0A03FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 6.579 s Processing PPM file: rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx [BB5,XSR 1.6] size: 8.01 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 14 MB CMT FLASH,MuxOneNAND area [0A040000-0AE3FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 0.047 s Processing CNT file: RM645_ENO_10wk48v0.001.fpsx [BB5,XSR 1.6] size: 2.25 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 4 MB CMT FLASH,MuxOneNAND area [004E0000-008DFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 0.469 s Processing CNT file: rm645_071.005_U000.000_prd.uda.fpsx [BB5,XSR 1.6] size: 1.32 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 72 MB CMT FLASH,MuxOneNAND area [0AE40000-0F63FFFF] Flash programming ... Programming completed in 0.672 s Total time for flashing process(boot+erase+write) was 53.844 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia C5-00 USB Phonet, PORT_ID: 59812AD Verifying communication to device OK. Phone type: RM-645 (Nokia C5-00) SW version: V ICPR82_11w16.4 02-06-11 RM-645 (c) Nokia ApeCoreSw: 071.005 Imei plain: 35484704298014-0 Product code: 0597838 Battery voltage: 3724 mV, current: 183 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354847042980140 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Nokia C5-00 USB Phonet detached. |
05-17-2012, 08:12 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Dear Madni Bhai, very simple just go to Quick Fix Tab>tick BB5 RAP3Nand Erase>click Do Selected Job. Every time it happen like that before phone working & after flash only vibrate with local mode, just apply this will solve your problem. Best Regards, Zuber Chowdhry |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
05-17-2012, 08:51 | #8 (permalink) | |
Freak Poster Join Date: Feb 2008
Member: 699434 Status: Offline Thanks Meter: 47 | Quote:
05-17-2012, 09:06 | #11 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
BR, | |
07-15-2012, 15:41 | #13 (permalink) | ||
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Quote:
plz guide , how to erase ? thnx | ||
07-15-2012, 15:48 | #14 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | 1'st Do You Remove Camera if Your Set Not Work Properly Then Try To Hardware Ariea. http://forum.gsmhosting.com/vbb/f148...brate-1494315/ http://forum.gsmhosting.com/vbb/f148...c-usb-1327083/ |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed | spterminator | Main Sales Section | 0 | 08-08-1999 05:08 |
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only | spterminator | Main Sales Section | 0 | 08-01-1999 05:46 |
