..::c5 when power on only vibrate::..DONE. ..::c5 when power on only vibrate::..DONE. .Library version: 1.0.0.9274(01-03-2011), 1.0.0.15761(01-03-2011) Processing MCU file: rm645_062.001_prd.core.fpsx [BB5,XSR 1.6] size: 92.54 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 32964DD CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] CMT EM0 ID: 00000C35 CMT EM1 ID: 00000C30 CMT PUBLIC ID: 24200119D19403440F76D99CD507BF5BE50A6B2B CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3AC0 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Secondary boot loaded. FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 10.22.0 revision: 3.0 size: 0xAC123 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 32964DD Verifying communication to device OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Rpl(Certificate) backup already exist (C:\mobileEx\3.4\data\backup\BB5_35375704704229_CE RT.rpl). CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 170.06 MB CMT MuxOneNAND area [00020000-0003FFFF] CMT MuxOneNAND area [00060000-004DFFFF] CMT MuxOneNAND area [008E0000-0AE3FFFF] Formating partition ... Flash programming ... CMT PAPUBKEYS: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 (RAP Certificate v1 249) written. Programming completed in 15.281 s Processing PPM file: rm645_062.001_01.01_Euro1_prd.rofs2.fpsx [BB5,XSR 1.6] size: 43.94 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 51.00 MB CMT MuxOneNAND area [06D40000-0A03FFFF] Flash programming ... Programming completed in 7.360 s Processing PPM file: rm645_062.001_C00.01_DEFAULT_prd.rofs3.fpsx [BB5,XSR 1.6] size: 7.95 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 14.00 MB CMT MuxOneNAND area [0A040000-0AE3FFFF] Flash programming ... Programming completed in 0.171 s Processing CNT file: rm645_062.001_U000.000_prd.uda.fpsx [BB5,XSR 1.6] size: 1.32 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 72.00 MB CMT MuxOneNAND area [0AE40000-0F63FFFF] Flash programming ... Programming completed in 0.766 s Processing CNT file: RM645_ENO_10wk48v0.001.fpsx [BB5,XSR 1.6] size: 2.25 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 4.00 MB CMT MuxOneNAND area [004E0000-008DFFFF] Flash programming ... Programming completed in 0.547 s Total time for flashing process(boot+erase+write) was 36.750 s Waiting for device boot up ... Device found: nmwcdc\Nokia C5-00 USB Phonet, PORT_ID: A5DA844 Verifying communication to device OK. Phone Type: RM-645 (Nokia C5-00) SW Version: V ICPR82_10w34.4 09-12-10 RM-645 (c) Nokia Imei plain: 35375704704229-4 Product Code: 0593763 Battery voltage: 3878 mV ApeCoreSw: 062.001 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353757047042294 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
This is Hardware problem!!!! Replace or reball glass ic near headphone jack connector... with Same problem, i made working 2phones with this solution.... TRY IT AND POST RESULT.... BEST OF LUCK:):):) |
obviously two ways to fix.received one yesterday and fully fixed by flashing..set now ok n working fine |
this is 100% hardwear problem chek bsi line... after few time phone back to dead and only bzzz need to hardwear repair bsi line. chek batery conector. |
