10-19-2012, 14:36 | #1 (permalink) |
Freak Poster Join Date: Jul 2009 Location: machilipatnam
Member: 1080792 Status: Offline Sonork: 4d0ddc25d0db862fb2f2b62f1 Thanks Meter: 31 | 3110c security test failed |
10-19-2012, 14:51 | #4 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Go to Service Tab > Click Load from File > Select Address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-237.PM file, Now click Repair SD & click no to Pop Up Window, Click Write & Buscheck you will see the positive Result. BR, ZUBER | |
10-19-2012, 15:37 | #5 (permalink) |
Member: 1080792 Status: Offline Sonork: 4d0ddc25d0db862fb2f2b62f1 Thanks Meter: 31 | SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 359309020364727 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN this is the result please solve my problem |
10-19-2012, 17:52 | #7 (permalink) | |
Member: 1080792 Status: Offline Sonork: 4d0ddc25d0db862fb2f2b62f1 Thanks Meter: 31 | Quote:
i try this this after you post it but no use please tell me another source.????????? | |
10-19-2012, 18:13 | #8 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
Go to Service Tab > Click Load from File > Select Address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-237.PM file, AND Use two buttons 1 by 1 Now click Repair SD & PMM Then auth success Now Write pm Buscheck I hope positive Result That's all Still Same Contact Me PM. BR. Arsalan gsm2000. | |
10-20-2012, 16:29 | #9 (permalink) | |
SW version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35930902036472-7 Product code: 0550573 Battery voltage: 4665 mV, current: 149 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359309020364727 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Thanks my problem security test failed is solved. but new complant is no signal i write good pm but same problem. before contact service set is have good signal. Respected member please solve this problem | |
10-20-2012, 18:11 | #10 (permalink) |
Member: 1080792 Status: Offline Sonork: 4d0ddc25d0db862fb2f2b62f1 Thanks Meter: 31 | Respected team please check before security test failed and after. I think some items are missing. please check SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid s CMLA_KEY seemto be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 359309020364727 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN after security test ok Phone type: RM-237 (Nokia 3110c) SW version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35930902036472-7 Product code: 0550573 Battery voltage: 4685 mV, current: 147 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359309020364727 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN i observed this keys are missing CMLA_KEY seems to be valid WMDRM_PD seems to be valid please check and give me correct direction. present set is no signal complaint. |
10-20-2012, 19:49 | #11 (permalink) |
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | CMLA_KEY seems to be valid WMDRM_PD seems to be valid Dear It's normal and valid is this not issue. Network search manually then show no network found It's confirm 100% Hardware Problem. BR. Arsalan gsm2000. |
10-20-2012, 20:03 | #12 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | You very Complicated & Massed up with many for simple one. OK! Do one thing, 1-Extract my attached PM in Mxkey Backup folder, 2-Backup RPL only NPC Data on IMEI & Security Tab, Give some different name to this Backup RPL, 3-Go to PM Tab > Load my PM & Click Write, 4-Go to IMEI & Security Tab > Write NPC Backup RPL manually, 5-Go to Simlock > Tick Init Simlock & Click Update Simlock. Now Buscheck, then Check Network & Post Result. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
10-22-2012, 07:07 | #13 (permalink) | |
Thanks for help its working Phone type: RM-237 (Nokia 3110c) SW version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35930902036472-7 Product code: 0550573 Battery voltage: 4837 mV, current: 69 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359309020364727 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Mx Key Team is VERY VERY Big supportfor users | |
