Old 10-22-2012, 15:23   #1 (permalink)
drsty's Avatar
Member: 1033768
Sonork: sonork_id=100.1603335
Thanks Meter: 81
help me nokia x2 full flash but set restart
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C08011F1
Using device: USB ROM and HTI, FW ver: 00.50, SN: 000009FC
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Processing MCU file: rm618__08.35.mcusw
[BB5,XSR 1.6] size: 26.97 MB
Supported Ids: 2200050920030000, 22000509200C0000
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
CMT EM0 ID: 00005361
CMT PUBLIC ID: 0000000000F6889925A79F5D550571958010A332
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
CMT ROM ID: DE56D582BDDE7A3A
Loading CMT secondary boot code
SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2439CE5C
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD3 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Rpl(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35536704715663_CE RT.rpl).
CMT PAPUBKEYS HASH: E9700989029D9E899915F781B1582048E042A738
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 32.88 MB
CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
CMT FLASH,MuxOneNAND area [00020000-000203FF]
CMT FLASH,MuxOneNAND area [00060000-011BFFFF]
CMT FLASH,MuxOneNAND area [011C0000-01CFFFFF]
CMT FLASH,MuxOneNAND area [02500000-028FFFFF]
Formating partition ...
Flash programming ...
CMT KEYS block sent
CMT PAPUBKEYS: E9700989 [RAP Certificate v1 237] sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT ADA block sent
CMT RAP3NAND block sent
CMT ISA+DYNSW block sent
CMT MCUSW block sent
CMT MCUSW1 block sent
CMT GENIO_INIT block sent
CMT UPDAPP block sent
Programming completed in 7.344 s
Processing PPM file: rm618__08.35.ppm_c
[BB5,XSR 1.6] size: 6.20 MB
Erase size: 8 MB
CMT FLASH,MuxOneNAND area [01D00000-024FFFFF]
Programming completed in 1.656 s
Processing CNT file: rm618__08.35.image_cib_059F935
[BB5,XSR 1.6] size: 19.11 MB
Erase size: 76.31 MB
CMT FLASH,MuxOneNAND area [02900000-0753FFFF]
Programming completed in 5.203 s
Total time for flashing process(boot+erase+write) was 22.438 s
Waiting for device boot up ...
Phone type: RM-618 (Nokia X2-00)
SW version: V 08.35 09-01-12 RM-618 (c) Nokia
Imei plain: 35536704715663-7
Product code: 059B611
Battery voltage: 3917 mV, current: 185 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: NI00BC0000040A4E2000, ver: 003.005
SIMLOCK seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 355367047156637
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 10-22-2012, 15:55   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Hi,
Run Selftest for Error,
Check LCD & Connector, MMC IC for Waterlogs.
BR,
ZUBER
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Old 10-22-2012, 16:56   #3 (permalink)
fortunemobile's Avatar
Member: 1728389
Sonork: 100.1617627
Thanks Meter: 57
hello go to service tab<action and click on reset all or factory set ur phone manually.
Old 10-22-2012, 19:10   #4 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
SIMLOCK_TEST passed
Imei:355367047156637
All is Fine Bro.It's hardware problem i face this issue 100% tested combo ic reheat All is well It's Water damage phone.
BR.
Arsalan gsm2000.
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post:
Page generated in 0.12884 seconds with 8 queries
